Deadline exceeded issue
Hi, Could you please help to solve the below issue?
Try decreasing the number of windows or reducing the number of training cycles. If the error persists then you can contact support at hello@edgeimpulse.com to increase this time limit.
Thanks in advance.
Best regards,
Shakhizat
Hi @shakhizat,
Please send your project ID number to hello@edgeimpulse.com. We can help you there.
Thanks Shawn for your reply, project id is 45666.
Hi @shakhizat,
I was able to increase your project processing time to 60 minutes.
Thanks Shawn, really appreciate that. Awesome and very understandable platform.
hello,I also encounter the same question. Could you help me to solve it? My project ID is 91907.@ shawn_edgeimpulse
Hi @lengyue ,
From your project, your training seems to have gone through. Let me know if you face any other challenge.
Clinton
It has indeed been completed, but adding new data exceeds the limited time
I still have more data needed to be add.And if I reduce the cycles, the accuracy can not satisfy my need
Hi @lengyue ,
I have just increased your time limit to 60 mins. Let me know if this helps!
Clinton
OK,I will try. And thank you very much.
em,there is nothing changed. it is still a 20 minute limitation. Could you check it for me?
Hi @lengyue ,
Could you check again to confirm that the changes have been enforced?
Thanks,
Clinton
OK,it has been changed. Thank you for your patient. It is really of great help for me.
Perfect!
Regards, Clinton
