Hello, i have used Nicla Sense ME to collect data and build a model. Is there a way to do the same wirelessly via ble, cause i’d eventually like to classify body movements and a cable would make things a bit difficult.
@apfotopoulos
You could open a Bluetooth port on your PC with your favorite Serial Monitor that would save the stream to a mass storage device. Then use the Edge Impulse (EI) Studio Data Acquisition page to upload your file in this format.
Even better for easy and efficient upload to EI Studio, write a custom serial stream reader that:
- parses the Bluetoooth stream,
- adds in the movement category,
- saves the data in the EI format mentioned above, and
- saves the file like this so your data gets Labeled automagically during the Upload.
