I flashed the Windows Batch file and then ran the edge impulse daemon command for my Arduino Nano BLE 33 Sense. It worked well and said that it was connected to COM8. I went to my project and thought collecting some accelerometer data. The length was 10000ms or 10secs and the frequency was 62.5Hz. It said that the sampling started and I moved the Arduino to make some data. But after the sampling was over the data didn’t get uploaded and no errors were there. I waited for sometime but still nothing was there. If anyone has any fix then please help me.
Here is the output :
I have the exact same issue.
I can upload the microphone data but nothing happens while using the accelerometer.
I’m using Chrome browser and Windows 10.
Looking forward for an answer.
I’ve found a workaround. Instead of using edge-impulse-daemon to upload the accelerometer data, I used the edge-impulse-forwarder.
For that I upload a code to the MCU (in my case I used Arduino IDE) that basically keeps printing the data of the sensors in an interval of time. After that, I called edge impulse forwarder and it worked.
If you need help with this code, let me know.
