I’ve been messing around with trying to a deploy a modified version of the MFE audio processing block but am currently in dependency hell. I’ve followed the custom deployment block tutorial, but using the MFE block as a base (https://github.com/edgeimpulse/processing-blocks/tree/master/mfe). However I quickly run into the issue that pip cannot find a match for the distro-info===0.23ubuntu1 requirement, and even if I bypass that, I get an issue with the pycairo dependency where it fails when trying to build the wheel. Is there some other set up I have to do with my build environment for this dockerfile to build correctly?
BTW I am using the latest Docker for Windows with the WSL2 backend
