Custom block error. "ValueError: cannot copy sequence with size 106 to array axis with dimension 105"
I am trying to extract RR intervals as features from an ECG dataset. Everything seems ok in the first custom block view, but when I try to generate features I got this error:
This is the dsp.py code I used:
import numpy as np
from hrvanalysis import remove_outliers, remove_ectopic_beats, interpolate_nan_values
from hrvanalysis import get_time_domain_features
from hrvanalysis import get_nn_intervals
import json
import peakutils
def smoothing(y, box_pts):
    box = np.ones(box_pts) / box_pts
    y_smooth = np.convolve(y, box, mode='same')
    return y_smooth
# define hrv - da MainCodeYT *Angelo
def hrv(data, fs):
    # find peaks
    r_peaks = peakutils.indexes(data, thres=0.5, min_dist=0.1)
    # RR intervals
    RR_intervals = np.diff(r_peaks)/fs
    return RR_intervals
def generate_features(draw_graphs, raw_data, axes, sampling_freq, scale_axes, smooth):
    # features is a 1D array, reshape so we have a matrix with one raw per axis
    raw_data = raw_data.reshape(int(len(raw_data) / len(axes)), len(axes))
    features = []
    smoothed_graph = {}
    # split out the data from all axes
    for ax in range(0, len(axes)):
        X = []
        for ix in range(0, raw_data.shape[0]):
            X.append(raw_data[ix][ax])
        # X now contains only the current axis
        fx = np.array(X)
        # first scale the values
        fx = fx * scale_axes
        # if smoothing is enabled, do that
        if (smooth):
            fx = smoothing(fx, 5)
        # extract features from fx *Angelo
        fx = hrv(fx, sampling_freq)
        # we save bandwidth by only drawing graphs when needed
        if (draw_graphs):
            smoothed_graph[axes[ax]] = list(fx)
        # we need to return a 1D array again, so flatten here again
        for f in fx:
            features.append(f)
    # draw the graph with time in the window on the Y axis, and the values on the X axes
    # note that the 'suggestedYMin/suggestedYMax' names are incorrect, they describe
    # the min/max of the X axis
    graphs = []
    if (draw_graphs):
        graphs.append({
            'name': 'DSP Graph',
            'X': smoothed_graph,
            'y': np.linspace(0.0, raw_data.shape[0] * (1 / sampling_freq) * 1000, raw_data.shape[0] + 1).tolist(),
            #'y': np.linspace(0.0, 5, 1).tolist(),
            'suggestedYMin': -20,
            'suggestedYMax': 20
    return { 'features': features, 'graphs': graphs }
The dsp-server.py code I used is the one given here https://docs.edgeimpulse.com/docs/custom-blocks.
The CSV input file is this:
timestamp,ECG
0,4.725
4,4.735
8,4.725
12,4.715
16,4.72
399996,4.765
Anyone could help me with this problem?
Thanks,
Angelo
Hi Angelo,
It looks like the generated features have different lenghts. I think it’s related to the peak detection algorithm as the function would return a list with a variable lengths. Could you modify your code to generate fixed size features?
Yeah an easy way is just set the length to (e.g.) 200 and zero out when you don’t find any RR intervals anymore.
Thank you so much! I tried with a fixed size list and it’s working fine.
