Unfortunately I’m unable to import csv data as described in the manual
CSV can be found here
ERROR:
[1/1] Failed to upload dummy_sample0.csv x-bounding-boxes is not valid json
What does this mean?
ERROR:
I just experienced the same error while importing images, we are currently investigating. It might come from a recent changes while adding the support of the bounding boxes import from the uploader. Thanks for letting us know.
I will keep you informed on the fixes.
Hello @fferket,
Our core engineering team has been noticed. In the meantime, you can use the CLI to upload your CSV:
edge-impulse-uploader your-file.csv --category split --clean
Let me know if you need some help.
Thank you for the quick support and providing a workaround.
Also the ei_uploaders seems not to support the csv format provided. Please see my output below:
Hello @fferket.
This issues has been solved.
Let me known if you still encounter the issue.
Hi louis,
Confirmed! Thank you!
