Question/Issue: I want to count objects in an taken image and I have follows the step in this tutorial: Count objects using FOMO - Edge Impulse Documentation
I am using ESP-EYE with ESP-IDF 4.4, and I have download this source code “GitHub - edgeimpulse/firmware-espressif-esp32: Edge Impulse firmware for the Espressif ESP-EYE(ESP32) Development board” then modify it like the tutorial:
ei_run_camera_impulse.cpp:
/* Edge Impulse ingestion SDK
- Copyright (c) 2022 EdgeImpulse Inc.
- Permission is hereby granted, free of charge, to any person obtaining a copy
- of this software and associated documentation files (the “Software”), to deal
- in the Software without restriction, including without limitation the rights
- to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
- copies of the Software, and to permit persons to whom the Software is
- furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in
- all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
- SOFTWARE.
/* Include ----------------------------------------------------------------- */
#include “model-parameters/model_metadata.h”
#if defined(EI_CLASSIFIER_SENSOR) && EI_CLASSIFIER_SENSOR == EI_CLASSIFIER_SENSOR_CAMERA
#include “edge-impulse-sdk/classifier/ei_run_classifier.h”
#include “edge-impulse-sdk/dsp/image/image.hpp”
#include “ei_camera.h”
#include “firmware-sdk/at_base64_lib.h”
#include “firmware-sdk/jpeg/encode_as_jpg.h”
#include “stdint.h”
#include “ei_device_espressif_esp32.h”
#include “ei_run_impulse.h”
#include “esp_timer.h”
#define DWORD_ALIGN_PTR(a) ((a & 0x3) ?(((uintptr_t)a + 0x4) & ~(uintptr_t)0x3) : a)
typedef enum {
INFERENCE_STOPPED,
INFERENCE_WAITING,
INFERENCE_SAMPLING,
INFERENCE_DATA_READY
} inference_state_t;
static inference_state_t state = INFERENCE_STOPPED;
static uint64_t last_inference_ts = 0;
static bool debug_mode = false;
static bool continuous_mode = false;
static uint8_t *snapshot_buf = nullptr;
static uint32_t snapshot_buf_size;
static ei_device_snapshot_resolutions_t snapshot_resolution;
static ei_device_snapshot_resolutions_t fb_resolution;
static bool resize_required = false;
static uint32_t inference_delay;
// Define the top of the image and the number of columns
static int TOP_Y = 50;
static int NUM_COLS = 5;
static int COL_WIDTH = EI_CLASSIFIER_INPUT_WIDTH / NUM_COLS;
static int MAX_ITEMS = 10;
// Define the factor of the width/height which determines the threshold
// for detection of the object’s movement between frames:
static float DETECT_FACTOR = 1.5;
// Initialize variables
std::vector count(NUM_COLS, 0);
int countsum =0;
int notfoundframes = 0;
std::vector<std::vector<ei_impulse_result_bounding_box_t> > previous_blobs(NUM_COLS);
size_t pixel_ix = offset * 3;
size_t pixels_left = length;
size_t out_ptr_ix = 0;
while (pixels_left != 0) {
out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix + 2];
// go to the next pixel
out_ptr_ix++;
pixel_ix+=3;
pixels_left--;
// and done!
return 0;
void ei_run_impulse(void)
switch(state) {
case INFERENCE_STOPPED:
// nothing to do
return;
case INFERENCE_WAITING:
if(ei_read_timer_ms() < (last_inference_ts + inference_delay)) {
return;
state = INFERENCE_DATA_READY;
break;
case INFERENCE_SAMPLING:
case INFERENCE_DATA_READY:
if(continuous_mode == true) {
state = INFERENCE_WAITING;
break;
default:
break;
uint8_t *jpeg_image;
uint32_t jpeg_image_size = 0;
EiCameraESP32 *camera = static_cast<EiCameraESP32*>(EiCameraESP32::get_camera());
ei_printf("Taking photo...\n");
if(camera->ei_camera_capture_jpeg(&jpeg_image, &jpeg_image_size) == false) {
ei_printf("ERR: Failed to take a snapshot!\n");
return;
snapshot_buf = (uint8_t*)ei_malloc(snapshot_buf_size);
if(snapshot_buf == nullptr) {
return;
if(camera->ei_camera_jpeg_to_rgb888(jpeg_image, jpeg_image_size, snapshot_buf) == false) {
ei_printf("ERR: Failed to decode JPEG image\n");
ei_free(snapshot_buf);
ei_free(jpeg_image);
return;
int64_t fr_start = esp_timer_get_time();
if (resize_required) {
snapshot_buf,
fb_resolution.width,
fb_resolution.height,
snapshot_buf,
snapshot_resolution.width,
snapshot_resolution.height);
int64_t fr_end = esp_timer_get_time();
if (debug_mode) {
ei_printf("Time resizing: %d\n", (uint32_t)((fr_end - fr_start)/1000));
ei::signal_t signal;
// print and discard JPEG buffer before inference to free some memory
if (debug_mode) {
ei_printf("Begin output\n");
ei_printf("Framebuffer: ");
// base64_encode((const char*)jpeg_image, jpeg_image_size, &ei_putchar);
int ret = encode_rgb888_signal_as_jpg_and_output_base64(&signal, EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT);
ei_printf("\r\n");
if(ret != 0) {
ei_printf("ERR: Failed to encode frame as JPEG (%d)\n", ret);
// run the impulse: DSP, neural network and the Anomaly algorithm
EI_IMPULSE_ERROR ei_error = run_classifier(&signal, &result, false);
if (ei_error != EI_IMPULSE_OK) {
ei_printf("ERR: Failed to run impulse (%d)\n", ei_error);
return;
// print the predictions
ei_printf(“Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms., Count: %d ): \n”,
result.timing.dsp, result.timing.classification,result.timing.anomaly, countsum);
std::vector<std::vector<ei_impulse_result_bounding_box_t> > current_blobs(NUM_COLS);
if (bb.value == 0) {
continue;
// Check which column the blob is in
int col = int(bb.x / COL_WIDTH);
// Check if blob is within DETECT_FACTOR*h of a blob detected in the previous frame and treat as the same object
for (auto blob : previous_blobs[col]) {
if (abs(int(bb.x - blob.x)) < DETECT_FACTOR * (bb.width + blob.width) && abs(int(bb.y - blob.y)) < DETECT_FACTOR * (bb.height + blob.height)) {
// Check this blob has “moved” across the Y threshold
if (blob.y >= TOP_Y && bb.y < TOP_Y) {
// Increment count for this column if blob has left the top of the image
count[col]++;
countsum++;
// Add current blob to list
current_blobs[col].push_back(bb);
//ei_printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n", bb.label, bb.value, bb.x, bb.y, bb.width, bb.height);
previous_blobs = std::move(current_blobs);
ei_printf(" Count: %d\n",countsum);
if (bb_found) {
notfoundframes = 0;
else {
notfoundframes ++;
if (notfoundframes == 1){
ei_printf(" No objects found\n");
else {
#else
ei_printf(" %s: %.5f\n", result.classification[ix].label,
#endif
#endif
if (debug_mode) {
ei_printf("\r\n----------------------------------\r\n");
ei_printf("End output\r\n");
if(continuous_mode == false) {
ei_printf("Starting inferencing in %d seconds...\n", inference_delay / 1000);
void ei_start_impulse(bool continuous, bool debug, bool use_max_uart_speed)
snapshot_resolution.width = EI_CLASSIFIER_INPUT_WIDTH;
snapshot_resolution.height = EI_CLASSIFIER_INPUT_HEIGHT;
debug_mode = debug;
continuous_mode = continuous;
EiDeviceESP32* dev = static_cast<EiDeviceESP32*>(EiDeviceESP32::get_device());
// check if minimum suitable sensor resolution is the same as
// desired snapshot resolution
// if not we need to resize later
fb_resolution = camera->search_resolution(snapshot_resolution.width, snapshot_resolution.height);
if (snapshot_resolution.width != fb_resolution.width || snapshot_resolution.height != fb_resolution.height) {
resize_required = true;
if (!camera->init(snapshot_resolution.width, snapshot_resolution.height)) {
ei_printf("Failed to init camera, check if camera is connected!\n");
return;
snapshot_buf_size = fb_resolution.width * fb_resolution.height * 3;
ei_printf("\tImage resolution: %dx%d\n", EI_CLASSIFIER_INPUT_WIDTH, EI_CLASSIFIER_INPUT_HEIGHT);
inference_delay = 10000000;
else {
inference_delay = 10000000; // Đặt khoảng thời gian chụp ảnh và đếm lại ở đây
if (use_max_uart_speed) {
ei_printf("OK\r\n");
ei_sleep(100);
dev->set_max_data_output_baudrate();
ei_sleep(100);
while(!ei_user_invoke_stop()) {
// Thêm vòng lặp để đảm bảo luôn chạy quá trình chụp ảnh và đếm số lượng vật thể
while (state != INFERENCE_STOPPED) {
ei_run_impulse();
ei_printf("Countsum: %d\n", countsum); // In ra biến countsum sau mỗi lần chạy ei_run_impulse
ei_sleep(1);
if (!continuous_mode) {
ei_sleep(inference_delay / 1000);
ei_stop_impulse();
ei_printf("\r\nOK\r\n");
ei_sleep(100);
dev->set_default_data_output_baudrate();
ei_sleep(100);
void ei_stop_impulse(void)
bool is_inference_running(void)
return (state != INFERENCE_STOPPED);
#endif /* defined(EI_CLASSIFIER_SENSOR) && EI_CLASSIFIER_SENSOR == EI_CLASSIFIER_SENSOR_CAMERA */
main.cpp:
- SOFTWARE.
#include “driver/gpio.h”
#include “sdkconfig.h”
#include <stdio.h>
#include “ei_at_handlers.h”
#include “ei_classifier_porting.h”
#include “freertos/FreeRTOS.h”
#include “freertos/task.h”
EiDeviceInfo *EiDevInfo = dynamic_cast<EiDeviceInfo *>(EiDeviceESP32::get_device());
static ATServer *at;
uint32_t elapsed_time = 0;
// Hàm để kiểm tra xem đã đủ 10 giây chưa
bool is_10_seconds_elapsed() {
if (elapsed_time >= 10000) { // 10 giây = 10000 ms
return true;
return false;
extern “C” void app_main() {
gpio_pad_select_gpio(GPIO_NUM_21);
gpio_reset_pin(GPIO_NUM_21);
gpio_pad_select_gpio(GPIO_NUM_22);
gpio_reset_pin(GPIO_NUM_22);
gpio_set_direction(GPIO_NUM_21, GPIO_MODE_OUTPUT);
gpio_set_direction(GPIO_NUM_22, GPIO_MODE_OUTPUT);
ei_printf(
"Hello DMM\r\n"
"Compiled on %s %s\r\n",
__DATE__,
__TIME__);
at = ei_at_init(dev);
ei_printf("Type AT+HELP to see a list of commands.\r\n");
at->print_prompt();
dev->set_state(eiStateFinished);
while(1) {
if (is_10_seconds_elapsed()) {
break;
// Start Edge Impulse inference
ei_start_impulse(false, false, false);
// Check if inference is running and print count
while (is_inference_running()) {
ei_run_impulse();
elapsed_time += 1000; // Cộng thêm 1 giây (1000 ms)
vTaskDelay(1000 / portTICK_PERIOD_MS);
AND THIS IS MY OUTPUT:
Starting inferencing in 2 seconds…
Predictions (DSP: 324 ms., Classification: 4 ms., Anomaly: 0 ms.):
- helloworld: 0.000000*
- noise: 0.894531*
- unknown: 0.105469*
Predictions (DSP: 324 ms., Classification: 4 ms., Anomaly: 0 ms.): - helloworld: 0.000000*
- noise: 0.941406*
- unknown: 0.058594*
There are nothing about the taking image process and there are no result of counting objects system?
I want the system to do: taking image => process image and count the objects => print results only.
Please help me!
