In the documentation data acquisition, It is mentioned that there is a option to classify using own model. I couldn’t find it in my project. Im using bounding box labeling method.
Do i need to change any setting to get that option?
Yes, you need to have a dataset that is unlabelled in your data acquisition tab, from there you will notice something called a labelling queue. You click on it and then you can see the images. You can select your model from the right side and then start labelling with it.
