I’m following the device connection instructions for arduino nano ble sense. When I get to the step to flash the impulse edge firmware onto the device I’m getting this message:
Has anyone else encountered this, if so please share any known workaround.
Just to confirm I have:
- installed node.js (version listed above)
- have the arduino CLI in my user folder
- have installed Edge Impulse CLI via command line
- have the flash_windows file in the same folder as arduino CLI
Thanks,
Nick
Sorry, I have solved this. My mistake is that when I moved the “flash_windows” file to my user directory I failed to include the BIN file highlighted below. Once I put that file there it worked fine.
Sorry for any bother.
Nick
@NRobinson2 Thanks for reporting back! FYI, if you add the arduino-cli to your PATH you should not need to move the files around, just double click on flash_windows and you’re good to go.
@NRobinson2 Thank you for clearing this out. I just had the same issue and resolved it with your help. Cheers!
