I am trying to collect audio samples from the microphone of the MCU using Edge Impulse. After completing the sampling and downloading the file, I see that the file is in .cbor format. But my required audio format is .ogg format. Is there any way to convert the .cbor files to the .ogg format?
Thanks in advance
I have been using the acclerometer sensor. Switched to microphone and was able to get the file in .wav format. WIll use other online converters. My bad!
@suburban-daredevil Also you can go to Export data from data acquisition, and select ‘.wav’ format there. It’ll give you all files in WAV format in one go
