I am working with FOMO in Edge Impulse. I successfully deployed my model in the .eim format on a Raspberry Pi. Now, for other purposes, I would like to convert the .eim file to .tflite format on my Raspberry Pi. If anyone knows how to do this, please help. I searched in Edge Impulse to see if I could export it directly as a .tflite file, but I couldn’t find the TensorFlow Lite option.
Also, if anyone knows how to use the output from the .eim file without converting it to TensorFlow Lite (.tflite), I would be extremely grateful.
The Tensor Flow Lite model can be downloaded from the EI Studio Dashboard page of your project.
The dashboard of my project does not provide the option to export the model in the TensorFlow Lite format.
I am not sure what is going on. My FOMO project shows:
Thank you. I have now found this information on my homepage. However, I have another question because I’m a little bit confused. I initially thought that to download the model, I needed to go to the deployment page and choose the desired format for my model there. In my case, the .tflite format is not available as an option.So, my question is, do the suggestions in the screenshot indicate that I can download the entire model? I apologize if my question seems stupid, as I am new to working on this type of project.
the tflite file by itself is just the computation graph. to actually connect it to the rest of your product you need to do things such as 1) wrapping in an engine to run it and 2) handling the pre/post processing. these, plus a bunch more, are the extra pieces you get with a deployment.
mat
Thank you. Is the .lite file similar to the .tflite file?
the .lite
file you can download is a tflite file.
mat
How do I run mymodel.eim in a python script an print the output .
This code will run a FOMO EIM.
In general start with the Edge Impulse Linux SDK for Python.
