I am interested in running the Response-to-Voice on a raspberry pi 4 using c++. I used the generic main file and make file from the standalone inference tutorial was able to get it to run once but I am not sure how to cycle in the data from the microphone and classify the information continuous. I looked for information on a microphone_continuous function like in the Arduino Nano ble but couldn’t find this same function for the raspberry pi 4 when I looked through my header files. Please advise.
Hi @mdchestn,
The Linux C++ SDK has an example for continuous audio inferencing, you can check the source code here: https://github.com/edgeimpulse/example-standalone-inferencing-linux/blob/master/source/audio.cpp
Let me know if that helps,
Hi @aurel ,
I found this tutorial a few weeks ago but my students were unable to get it to run. If I understand it and you correctly this is pretty much all I need to sample a voice and run it in c++ on the raspberry pi 4.
Hi @aurel ,
I tried running the tutorial you pointed me towards but I get an error when I tried to run the Audio classifier and not the custom sensor version. Do you have any advice?
Hi @aurel
The following error occurs whenever I type in APP_AUDIO= 1 make -j
source/audio.cpp:238:44: error: ‘classifier_maf’ was not declared in this scope; did you mean ‘classifier_buffer’?
238 | run_moving_average_filter(&classifier_maf[ix], result.classification[ix].value);
@aurel ,
it doesn’t seem to recognize &classifier_maf[ix] and I only could find this variable in two locations within the whole program. My advisor suggested the it could be in the ei_run_classifier.h file but I didn’t see it.
@mdchestn, we did some changes on the moving average filter recently so I’m checking with our embedded team, I will keep you posted.
In the meantime you can also disable the MAF (use_maf = false).
Hi @aurel ,
I commented out the sections that included the classifer_maf[ix], because the use_maf= false didn’t work and this worked for me but now it is saying the following when I run ./build/audio …
Requires one parameter (ID of the sound card) in the form of plughw:1,0 (where 1=card number, 0=device).
You can find these via cat /proc/asound/cards. E.g. for:
0 [Headphones ]: bcm2835_headphonbcm2835 Headphones - bcm2835 Headphones
bcm2835 Headphones
1 [Webcam ]: USB-Audio - C922 Pro Stream Webcam
C922 Pro Stream Webcam at usb-0000:01:00.0-1.3, high speed
The ID for ‘C922 Pro Stream Webcam’ is then plughw:1,0
HI @aurel ,
Do I have to use that particular headset or can I point to the usb headset that I have plugged into the raspberry pi 4
Hi @mdchestn,
Linux and audio equipment (e.g. microphones) is always a tricky battle. I recommend following along with the error output. Run this command with your headphones plugged in:
You should see something like plughw:x,y (e.g. plughw:1,0). Use that as a parameter when calling the compiled binary. For example:
./build/audio plughw:x,y
Hi @aurel and @shawn_edgeimpulse ,
Thank you both for your help your information allowed my research students to accomplish their task for the week.
Hi @shawn_edgeimpulse and @aurel,
Do either of you know why our code would suddenly crash after running? We only made a few modifications but this is coming up:
Failed to read audio data (-32)
Hi @mdchestn,
Without knowing what modifications you made, I cannot say for sure why something is crashing. Does it run if you revert to your old version?
Hi @shawn_edgeimpulse ,
no it does not crash with the old version. We added the following code to the old version to the loop the prints the classifications:
if( result.classification[ix].label == “yes” && result.classification[ix].value >= .5){
yesCount=yesCount+1;
yesholder=1;
if(yesCount > 1 && yesCount%10==0){
sleep_for(milliseconds(1000));
system("vlc file:///home/mdchestn/Desktop/example-standalone-inferencing-linux/49_MusicBoxHat_790.wav --play-and-exit");
else{
if( result.classification[ix].label == "no" && result.classification[ix].value >=.5){
noCount=noCount+1;
noholder=1;
if(noCount > 1 && noCount%10==0){
system("vlc file:///home/mdchestn/Desktop/example-standalone-inferencing-linux/150_Upsweep_05_641.wav --play-and-exit");
else{
if((yesholder == 1) || (noholder == 1)){
printf("%s: %.05f", result.classification[ix].label, result.classification[ix].value);
printf(", ");
To give you brief description of what our code is suppose to do is play a sound on the detection of no and yes, once each has reached multiples of ten play the sound 3 times. And only print out the classification information when yes and no is detected.
Our code runs correctly for about 5 minutes and then all of a sudden the following error pops up:
And that time length isn’t consistent it does it sometimes after about 2 minutes.
Hi @shawn_edgeimpulse and @aurel ,
Thank you for your help again it was the timers that we included that was making it crash for some reason.
Never mind it just crashed after about 10 minutes, after we removed the timers. The old version of our code was working though.
