I’m trying to connect my Arduino Nano 33 BLE Sense to Edge Impulse on my MacBook Pro.
I have been following the documentation and it still won’t recognise my board, so I’ll just go through everything I’ve done and hopefully someone can help me.
Firstly, to download the Edge Impulse CLI, I downloaded Python 3 and Node.js. That went well.
Then i executed this in terminal and got this error back
npm install -g edge-impulse-cli --force
EACCES: permission denied, mkdir ‘/usr/local/lib/node_modules/edge-impulse-cli’
I followed the trouble shooting and executed this before trying again with the installation.
% sudo chown -R $USER /usr/local/lib/node_modules.
EACCES: permission denied, symlink ‘…/lib/node_modules/edge-impulse-cli/build/cli/blocks.js’ -> ‘/usr/local/bin/edge-impulse-blocks’
Then I guessed a solution and executed this before trying again with the installation
% sudo chown -R $USER /usr/local/bin/
Then I think my computer asked me to install something, which I did and I tried again and it seemed to work. Below is what my terminal outputted.
npm WARN using --force Recommended protections disabled.
npm WARN deprecated request-promise@4.2.4: request-promise has been deprecated because it extends the now deprecated request package, see
npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1.
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See
npm WARN deprecated request@2.88.0: request has been deprecated, see
added 385 packages, and audited 386 packages in 13s
12 packages are looking for funding
runnpm fundfor details
10 vulnerabilities (7 moderate, 1 high, 2 critical)
To address all issues (including breaking changes), run:
npm audit fix --force
Runnpm auditfor details.
Secondly, I installed the Arduino CLI. It’s unzipped and in my downloads folder.
Thirdly, I put my Arduino Nano 33 BLE Sense into bootloader mode and installed the latest Edge Impulse firmware. It’s in my downloads folder. I can’t unzip “arduino-nano-33-ble-sense.ino.bin” with Archive Utility or The Unarchiver on my Mac. This may be the issue.
Then I ran flash_mac.command and, as shown in the screenshot below, it thinks that I haven’t downloaded the Arduino CLI.
I can’t get much further than this…
I have tried manually dragging the arduino-cli into my usr/bin folder, so that it is in my path. That got me a bit further to the stage where you input your Edge impulse account, but it still couldn’t detect my board.
Please help me
