You will be able to run your impulse from that board. However, the provided examples with the sensors won’t work, you will need to implement how to collect the data yourself.
Also, the default firmware won’t work as it uses the sensors. But you can easily use the data-forwarded to collect data using this board.
TL;DR. Yes it can work, no it is not fully supported.
