Command failed - "APP_EIM=1 TARGET_JETSON_NANO=1 make -j" while running on Jetson nano
I have clonned one of the project to run on jetson nano. After following all the step, the final command that creates the model is creating issue.
The command - APP_EIM=1 TARGET_JETSON_NANO=1 make -j
Issue: Screenshot attached.
Its restarting the jetson nano device everytime.
Project ID - 585524
Object detection.
Followed the steps from the doc : High-resolution, High-speed Object Counting - Nvidia Jetson Nano (TensorRT) | Expert Projects
Run the model on jetson nano
Error after running the command - APP_EIM=1 TARGET_JETSON_NANO=1 make -j
Hi @ajithkjajith
It looks like you are missing the C++ compiler or have an incorrect version installed to support,
e.g. gcc 10 etc
sudo apt-get update
sudo apt-get install -y gcc-10 g++-10
export CC=gcc-10
export CXX=g++-10
See: NVIDIA Jetson | Edge Impulse Documentation
Running make -j without limiting the job count (-j$(nproc)) can overwhelm the Jetson Nano, especially if it’s USB-powered, you need to set a number for the amount of cores to target
Please also make sure you have a recent build of your project, and the latest jetson nano script installed:
wget -q -O - https://cdn.edgeimpulse.com/firmware/linux/jetson.sh | bash
Hopefully that will get you going if not please provide all of the versions of jetpack and details you can so our embedded team can review (details are in the message template)
cc @rjames in case i missed anything here.
Hi @Eoin ,
Thanks for the update.
The jetson nano that we are using is of 2GB Developer kit, that has power supply.
Loaded OS using Nvidia SDK manager.
Supports Ubuntu Version: 18
Jetpack: 4.6
I found that gcc-10 is not supported with ubuntu 18.04, then how exactly this project was achieved using jetson nano board: High-resolution, High-speed Object Counting - Nvidia Jetson Nano (TensorRT) | Expert Projects
