IoBytes
February 3, 2022, 4:55am
#1
I collected temp and humi data with wio terminal and successfully deployed, but now I need to implement with Arduino, I can see there is a specific static_buffer.ino but i don’t know how to implement static_buffer.ino with the Arduino or other Arduino supported hardware.
Thanks.
jenny
February 3, 2022, 9:48am
#2
Hi @IoBytes ,
Can you tell me which tutorials you have followed already from Wio Terminal? Here’s our documentation page for reference: https://docs.edgeimpulse.com/docs/seeed-wio-terminal
– Jenny
IoBytes
February 3, 2022, 10:50am
#3
I just followed this one to forward Temperature data to Edge impulse via Wio Terminal.
# Edge Impulse Data Forwarder
The data forwarder is used to easily relay data from any device to Edge Impulse over serial. Devices write sensor values over a serial connection, and the data forwarder collects the data, signs the data and sends the data to the ingestion service. The data forwarder is useful to quickly enable data collection from a wide variety of development boards without having to port the full [remote management protocol](https://docs.edgeimpulse.com/reference#remote-management) and [serial protocol](https://docs.edgeimpulse.com/reference#remote-mgmt-serial-protocol), but only supports collecting data at relatively low frequencies.
To use the data forwarder, load an application (examples for Arduino and Mbed OS below) on your development board, and run:
$ edge-impulse-data-forwarder
The data forwarder will ask you for the server you want to connect to, prompt you to log in, and then configure the device.
This is an example of the output of the forwarder:
Edge Impulse data forwarder v1.5.0
? What is your user name or e-mail address (edgeimpulse.com)? jan@edgeimpulse.com
? What is your password? [hidden]
Endpoints:
This file has been truncated. show original
