COCO Annotations not uploaded via Web Uploader
I am trying to upload my dataset in the COCO Format. When using the “Add existing data” >> “Upload Data” Form and upload a image folder with a coco annotations json file, the images are uploaded, but the annotations are note. In the log output, it is indicated, that the annotations file was successfully parsed.
Research on small object detection, trying to upload my dataset in COCO Format. The dataset is valid in other algorithms that use COCO Format.
Hi @roha
Can you share a notebook/gist with the example format you are working with or standard COCO JSON?
We have a comprehensive guideline on our annotation formatting here:
Hi @Eoin
It was my mistake - I mistook the “_annotations.coco.json” for a placeholder name
It was a bit confusing to me, since my coco json file (named “instances_train”), was correctly recognized and parsed from what I could see in the log and selecting it automatically displayed the “COCO, Boundingbox” selection in the UI. However, only if the file is named “_annotations.coco.json” , it will be correctly imported.
Thank you for your help!
Best, Rohan
