I tried to deploy a model on a new device, with a EFR32MG22C224F512IM40-C which has a Cortex-M33, and I’ve realised that CMSIS-DSP and CMSIS-NN are not being included and I’d like to know how could I use them.
Thanks Project ID:
Hi @JosuGaztelu,
Could you write what kind of deployment from the Studio you use (C++ Library, SLCC Component)?
Also, what toolchain/IDE do you use for compilation?
As a temporary workaround, try to set these three global defines: EIDSP_USE_CMSIS_DSP=1 EIDSP_LOAD_CMSIS_DSP_SOURCES=1 EI_CLASSIFIER_TFLITE_ENABLE_CMSIS_NN=1
I used the C++ library, and I did define those three global defines, but what I dont understand is why using those defines or not the inference time is always the same. The toolchain is GNU ARM v10.3.1 and I’m using the Simplicity Studio v5 as IDE.
I found out that it is due to the option of take log of spectrum, it causes to not have an impact between using or not CMSIS-DSP. I’m not sure if it is due to my processors specification so if anyone knows why could it be or could give me a hint I would be very grateful.
Is it possible to share your project source code? Or if you can build a minimal example where you are observing the same inference time regardless of the use of CMSIS-DSP and CMSIS-NN.
When selecting the spectral features as preprocessing block it has an otion to use logaritmic scale:
if this is selected CMSIS-DSP will not have any impact on DSP timing.
Should it have something to do maybe with the __ARM_FEATURE_DSP or any other define?
Hi I dont know what i did, but now it seems to be working correctly with new project and CMSIS-DSP now works correctly, maybe it could be that in this case i defines the __ARM_FEATURE_DSP=1.
Thanks for the answers
Hello, I was doing a project kind of keywordspotting, but I am seeing that the DSP is being done in floating point not using CMSIS-DSP. What should I do?because the the dsp is taking long when deploying the project on raspberry pico.
