When running edge-impulse-daemon with a pre-flashed firmware available in the turorial here, the deamon tool does not load config.
I have an hardware board from silicon labs labelled “BRD2601A” Rev00. After playing with the board with other firmware from Simplicity Studio, I massearased the board and flashed the firmware available in the tutorial. The board is not recognized as an usb stick as per say in the tutorial, also I don’t think the correct firmware is flashed on the board.When running the edge-impulse-daemon I have the following prompt (and it goes in a loop trying to read config):
edge-impulse-daemon
Edge Impulse serial daemon v1.17.3
Endpoints:
API: https://studio.edgeimpulse.com
? Which device do you want to connect to? /dev/tty.usbmodem0004402510971 (Silicon Labs)
[SER] Connecting to /dev/tty.usbmodem0004402510971
Setup: MAC M1 Arm based
Silabs board: BRD2601A
