Hi, I’m trying to classify images (One label per data item) using a Raspberry Pi 4, but I have a problem with It. When I run the impulse by the Edge Impulse Runner It classify correctly. But since I want it to do the identification locally and without internet, I need to use the Python example “Classify.py”. The issue I have is that the latter gives me a totally wrong result.
If you could help me, it would be very good for me because I have to deliver the work urgently, and I did not expect this error.
Can you share more on what is exactly wrong with results?
Secondly the Edge Impulse Runner can run offline once you’ve have downloaded the file locally.
The easiest way is to download the model from the Studio (Deployment page).
Once you have the model.eim you can run the specify the model when invoking the unner as follows:
The --force-target ensures you get the model built for aarch64.
The benifit of this approach is that you can run this command on either the host or the target.
The Edge Impulse Runner automaticaly detects your host and downloads the model for that host. But if for example you’re on a x86_64 and would like to download a model for AARCH64 then you can use --force-target for this.
By the way you’re running the above results on the Raspberry Pi 4?
Hi! Have you been able to get to what the problem of sorting is?
I had also tried to make another project with a new database, this is the project ID: 152847.
If it helps you, I use a Raspberry Cam 2.1 and when I switch between the CLI and the python I have to change the /boot/config.txt path.
Is it possible to test them both using the same overlay?
I tested with the python sdk custom/classifiy.py and features from your project and got (the same) correct results. I compared the Python SDK, Example Standalone Inferencing for Linux (APP_CUSTOM) and Studio.
My guess is that with the overlays you feed different input. Please try the above and share your findings.
Hi, I can’t test it with the same overlay, because with the dtoverlay=imx219 I get this error when I try to use the Python SDK:
MODEL: /home/tdrnil/modelfile.eim
Loaded runner for "Nil Casañé / Detecció d'objectes v2"
Looking for a camera in port 0:
File "/home/tdrnil/classify.py", line 148, in <module>
main(sys.argv[1:])
File "/home/tdrnil/classify.py", line 82, in main
raise Exception('Cannot find any webcams')
Exception: Cannot find any webcams
Hi!
I had been trying to make classify with the example for C++ but I had received this error when trying to execute APP_CUSTOM=1 TARGET_LINUX_ARMV7=1 USE_FULL_TFLITE=1 make -j:
make: *** No targets specified and no makefile found. Stop.
Also I tried what you told my about running the edge impulse runner offline, but this isn’t what I need because I want to export the classification to an Arduino.
Hi! Could you have been in the wrong directory? You should be in the project root. The the project root directory contains the Makefile (that couldn’t be found).
Hi!
I had been trying the command APP_CUSTOM=1 TARGET_LINUX_ARMV7=1 USE_FULL_TFLITE=1 make -j in the correct directory but I still get this error:
In file included from ./edge-impulse-sdk/classifier/ei_run_classifier.h:56,
from source/custom.cpp:27:
./edge-impulse-sdk/classifier/inferencing_engines/tflite_eon.h:30:10: fatal error: tflite-model/trained_model_compiled.h: No such file or directory
30 | #include "tflite-model/trained_model_compiled.h"
compilation terminated.
make: *** [Makefile:137: source/custom.o] Error 1
make: *** Waiting for unfinished jobs....
edge-impulse-sdk/tensorflow/lite/micro/kernels/rfft2d.cc: In function ‘TfLiteStatus tflite::ops::micro::rfft2d::Eval(TfLiteContext*, TfLiteNode*)’:
edge-impulse-sdk/tensorflow/lite/micro/kernels/rfft2d.cc:163:26: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
163 | for (size_t ix = 1; ix < input->dims->size; ix++) {
edge-impulse-sdk/tensorflow/lite/micro/kernels/rfft2d.cc:167:26: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
167 | for (size_t ix = 1; ix < output->dims->size; ix++) {
edge-impulse-sdk/tensorflow/lite/micro/kernels/rfft2d.cc:171:28: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
171 | for (size_t row = 0; row < input->dims->data[0]; row++) {
edge-impulse-sdk/tensorflow/lite/micro/kernels/complex_abs.cc: In function ‘TfLiteStatus tflite::ops::micro::complex_abs::Eval(TfLiteContext*, TfLiteNode*)’:
edge-impulse-sdk/tensorflow/lite/micro/kernels/complex_abs.cc:67:34: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
67 | for (size_t dim_ix = 0; dim_ix < input->dims->size; dim_ix++) {
edge-impulse-sdk/tensorflow/lite/micro/kernels/real.cc: In function ‘TfLiteStatus tflite::ops::micro::real::Prepare(TfLiteContext*, TfLiteNode*)’:
edge-impulse-sdk/tensorflow/lite/micro/kernels/real.cc:58:34: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
58 | for (size_t dim_ix = 0; dim_ix < input->dims->size; dim_ix++) {
edge-impulse-sdk/tensorflow/lite/micro/kernels/real.cc:63:34: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
63 | for (size_t dim_ix = 0; dim_ix < output->dims->size; dim_ix++) {
edge-impulse-sdk/tensorflow/lite/micro/kernels/real.cc: In function ‘TfLiteStatus tflite::ops::micro::real::RealEval(TfLiteContext*, TfLiteNode*)’:
edge-impulse-sdk/tensorflow/lite/micro/kernels/real.cc:79:34: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
79 | for (size_t dim_ix = 0; dim_ix < input->dims->size; dim_ix++) {
edge-impulse-sdk/tensorflow/lite/micro/kernels/real.cc: In function ‘TfLiteStatus tflite::ops::micro::real::ImagEval(TfLiteContext*, TfLiteNode*)’:
edge-impulse-sdk/tensorflow/lite/micro/kernels/real.cc:97:34: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
97 | for (size_t dim_ix = 0; dim_ix < input->dims->size; dim_ix++) {
At global scope:
cc1plus: note: unrecognized command-line option ‘-Wno-asm-operand-widths’ may have been intended to silence earlier diagnostics
At global scope:
At global scope:
nil@tdrnil:~/example-standalone-inferencing-linux $ APP_CUSTOM=1 TARGET_LINUX_ARMV7=1 USE_FULL_TFLITE=1 make -j
g++ -Wall -g -Wno-strict-aliasing -I. -Isource -Imodel-parameters -Itflite-model -Ithird_party/ -Os -DNDEBUG -DEI_CLASSIFIER_ENABLE_DETECTION_POSTPROCESS_OP=1 -g -Wno-asm-operand-widths -DEI_CLASSIFIER_USE_FULL_TFLITE=1 -Itensorflow-lite/ -std=c++14 -c source/custom.cpp -o source/custom.o
In file included from ./edge-impulse-sdk/classifier/ei_run_classifier.h:21,
./model-parameters/model_metadata.h:120:2: error: #error "Cannot use full TensorFlow Lite with EON"
120 | #error "Cannot use full TensorFlow Lite with EON"
In file included from source/custom.cpp:27:
./edge-impulse-sdk/classifier/ei_run_classifier.h: In function ‘EI_IMPULSE_ERROR {anonymous}::run_inference(const ei_impulse_t*, ei::matrix_t*, ei_impulse_result_t*, bool)’:
./edge-impulse-sdk/classifier/ei_run_classifier.h:130:31: error: ‘run_nn_inference’ was not declared in this scope; did you mean ‘run_inference’?
130 | EI_IMPULSE_ERROR nn_res = run_nn_inference(impulse, fmatrix, result, debug);
| run_inference
In file included from source/custom.cpp:28:
./inc/bitmap_helper.h: In function ‘int create_bitmap_file(const char*, uint16_t*, size_t, size_t)’:
./inc/bitmap_helper.h:61:22: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘unsigned int’} [-Wsign-compare]
61 | for(int i = 0; i < h; i++) {
./inc/bitmap_helper.h: In function ‘int create_bitmap_file(const char*, float*, size_t, size_t)’:
./inc/bitmap_helper.h:121:22: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘unsigned int’} [-Wsign-compare]
121 | for(int i = 0; i < h; i++) {
source/custom.cpp: In function ‘int main(int, char**)’:
source/custom.cpp:77:96: warning: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 3 has type ‘std::vector<float>::size_type’ {aka ‘unsigned int’} [-Wformat=]
77 | printf("The size of your 'features' array is not correct. Expected %d items, but had %lu\n",
| long unsigned int
| %u
78 | EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, raw_features.size());
| std::vector<float>::size_type {aka unsigned int}
At global scope:
It looks like you deployed the C++ library with Enable EON Compiler enabled and are trying to use USE_FULL_TFLITE. They do not go together. Notice the error:
./model-parameters/model_metadata.h:120:2: error: #error “Cannot use full TensorFlow Lite with EON”
120 | #error “Cannot use full TensorFlow Lite with EON”
Disable EON Compiler and re-export your Edge Impulse C++ Library.
Remove the previous C++ library and place the new library.
Hi!
I had created the custom build but now I have two questions. The first one is that I don’t understand how to execute the identification. The other one is that I need to export the finally object that had been identified, is it possible with the c++ SDK?
I think I understood your previous post. I’ll try to answer.
You’ve built the custom app (APP_CUSTOM=1). You can use this to test the model on your target.
Go to your project and grab raw features:
Go to Live classification
Load a test sample (Load sample)
Copy the Raw features and paste into a file, say features.txt.
Then you run the custom app as follows:
./build/custom features.txt
and compare with the results you get in Studio.
If you want to get your camera sensor integrated you can build the APP_CAMERA=1 application. Note you’ll have to build OpenCV for your target. I wonder if you’ll encounter the same OpenCV issues you had previously with the python app. It’s worth a try.
