Hi ! I use a raspberry pi 4 with a hifiberry hat to collect data and it works, but the sampling frequency in the data aquisition window is set to 16kHz and can’t be adjusted. I can record with higher sampling frequencies with the same device when it’s not through edge impulse.
I would like to set a higher sampling frequency, do you know if that is possible ?
Hello @laetidrum,
I actually never tried this one (so I cannot 100% guarantee it works for audio), but we do have a custom-collect.ts example in our Edge Impulse Linux CLI in case you want to implement something custom yourself.
I just created a feature request so we can change the frequency directly from the CLI by passing an argument like --frequency 32000
