Cannot run edge-impulse-linux-runner on RPi4
upon following the instructions from: https://docs.edgeimpulse.com/docs/raspberry-pi-4, I’ve launched the “edge-impulse-linux”, I got the following error:
root@raspberrypi:~# edge-impulse-linux --api-key ei_<xyz>
Edge Impulse Linux client v1.3.0
? Select a microphone (or run this command with --disable-microphone to skip selection) bcm2835_headpho - bcm2835 Headphones
[SER] Using microphone hw:0,0
Failed to initialize linux tool Error code was not 0: Probing devices...
[15:20:57.457126108] [5257]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3156-f4070274
Failed to start device monitor!
My setup is:
RPi4, with a USB camera, running RaspberryPi OS Lite (Raspbian GNU/Linux 11 (bullseye)) (Linux raspberrypi 5.10.63-v7l+ #1459 SMP Wed Oct 6 16:41:57 BST 2021 armv7l GNU/Linux), and I have v1.3.0 of edge-impulse-linux
I confirm I can see the camera:
root@raspberrypi:~# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 046d:0826 Logitech, Inc. HD Webcam C525
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
And I also confirm “gst-device-monitor-1.0” cannot! So this libcamera dependency is somehow causing the problem. In debug mode, I see the following snippet:
0:00:00.805322294  3249   0xfc0200 DEBUG                GST_BUS gstbus.c:340:gst_bus_post:<bus0> [msg 0xfc1728] posting on bus device-added message: 0xfc1728, time 99:99:99.999999999, seq-num 1, element 'libcameraprovider0', GstMessageDeviceAdded, device=(GstDevice)"\(GstLibcameraDevice\)\ \(null\)";
0:00:00.805348998  3249   0xfc0200 DEBUG                GST_BUS gstbus.c:383:gst_bus_post:<bus0> [msg 0xfc1728] pushing on async queue
0:00:00.805373238  3249   0xfc0200 LOG                 GST_POLL gstpoll.c:290:raise_wakeup: 0xfb6888: raise
0:00:00.805408757  3249   0xfc0200 DEBUG                GST_BUS gstbus.c:386:gst_bus_post:<bus0> [msg 0xfc1728] pushed on async queue
0:00:00.805435331  3249   0xfc0200 TRACE        GST_REFCOUNTING gstminiobject.c:647:gst_mini_object_unref: 0xfc1728 unref 3->2
0:00:00.805461830  3249   0xfc0200 DEBUG                GST_BUS gstbus.c:383:gst_bus_post:<bus1> [msg 0xfc1728] pushing on async queue
0:00:00.805485441  3249   0xfc0200 LOG                 GST_POLL gstpoll.c:290:raise_wakeup: 0xfb68c8: raise
0:00:00.805514034  3249   0xfc0200 DEBUG                GST_BUS gstbus.c:386:gst_bus_post:<bus1> [msg 0xfc1728] pushed on async queue
0:00:00.805541219  3249   0xfc0200 TRACE        GST_REFCOUNTING gstobject.c:264:gst_object_unref:<GstLibcameraDevice@0x1084cd8> 0x1084cd8 unref 4->3
0:00:00.805570385  3249   0xfc0200 DEBUG                GST_BUS gstbus.c:498:gst_bus_set_flushing:<bus2> unset bus flushing
0:00:00.806436656  3249   0xfc0200 DEBUG                  pulse pulsedeviceprovider.c:534:gst_pulse_device_provider_start:<pulsedeviceprovider0> connect to server (NULL)
0:00:00.806822004  3249   0xfc0200 ERROR                  pulse pulsedeviceprovider.c:537:gst_pulse_device_provider_start:<pulsedeviceprovider0> Failed to connect: Connection refused
Hope you can help
Thanks in advance
Hi @cristovao.cordeiro,
You’ve used the same camera to collect data?
Can you try with the flag --clean to verify the camera is correctly selected?
Hi @aurel,
sorry, I was switching between hardware. The “edge-impulse-linux” command also fails, with the same error. This is related with the gst+libcamera dependencies
(I’ve edited the op)
just pinging to reactivate this thread. any help would be highly appreciated
I’m wondering if it’s related to using the OS Lite version, I have a Logitech camera too and don’t run into this issue. You could give it a try with the default OS version, I’ll also look into testing the Lite one.
I have the same issude with the OS Lite version. It looks like some packages related to camera management are missing in this version. Can you try with the default (full) OS version and let us know?
to avoid duplication, I’m moving this discussion to PI 4 with pi-Cam V2 setup issue
