Hi everyone, I want to create a drowsiness detector by using Raspberry Pi 4 model b, Picamera2 and an alarm buzzer but I cannot open a camera preview after I run my Python script. It keeps showing an error to me, looks like there is a problem with the index number, may I know how to check my Picamera2 index number?
I use bookworm OS
below is the code:
[0:03:00.542245672] [2552] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+118-563cd78e
[0:03:00.571168714] [2562] WARN RPiSdn sdn.cpp:39 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[0:03:00.573974638] [2562] INFO RPI vc4.cpp:444 Registered camera /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam device /dev/media0 and ISP device /dev/media1
[0:03:00.574054305] [2562] INFO RPI pipeline_base.cpp:1142 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:03:00.578403164] [2552] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+118-563cd78e
[0:03:00.606613276] [2565] WARN RPiSdn sdn.cpp:39 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[0:03:00.608878048] [2565] INFO RPI vc4.cpp:444 Registered camera /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam device /dev/media0 and ISP device /dev/media1
[0:03:00.608954253] [2565] INFO RPI pipeline_base.cpp:1142 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:03:00.614843528] [2552] INFO Camera camera.cpp:1183 configuring streams: (0) 640x480-XRGB8888 (1) 640x480-SGBRG10_CSI2P
[0:03:00.615262457] [2565] INFO RPI vc4.cpp:608 Sensor: /base/soc/i2c0mux/i2c@1/ov5647@36 - Selected sensor format: 640x480-SGBRG10_1X10 - Selected unicam format: 640x480-pGAA
[ WARN:0@2.620] global cap_v4l.cpp:997 open VIDEOIO(V4L2:/dev/video0): can't open camera by index
[ WARN:0@2.624] global obsensor_stream_channel_v4l2.cpp:82 xioctl ioctl: fd=67, req=-2140645888
[ WARN:0@2.624] global obsensor_stream_channel_v4l2.cpp:138 queryUvcDeviceInfoList ioctl error return: 25
[ERROR:0@2.626] global obsensor_uvc_stream_channel.cpp:159 getStreamChannelGroup Camera index out of range
This is my python script:
import cv2
import numpy as np
import dlib
from imutils import face_utils
from picamera2 import Picamera2
import RPi.GPIO as GPIO
buzzer_pin = 16
picam2 = Picamera2()
picam2.configure(picam2.create_video_configuration(main={"format": 'XRGB8888', "size": (640, 480)}))
picam2.start()
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
GPIO.setup(buzzer_pin, GPIO.OUT)
GPIO.output(buzzer_pin, GPIO.LOW)
cap = cv2.VideoCapture(0)
detector = dlib.get_frontal_face_detector()
predictor = dlib.shape_predictor("shape_predictor_68_face_landmarks.dat")
sleep = 0
drowsy = 0
active = 0
status = ""
color = (0, 0, 0)
def compute(ptA, ptB):
dist = np.linalg.norm(ptA - ptB)
return dist
def blinked(a, b, c, d, e, f):
up = compute(b, d) + compute(c, e)
down = compute(a, f)
ratio = up/(2.0*down)
if(ratio > 0.25):
return 2
elif(ratio > 0.21 and ratio <= 0.25):
return 1
else:
return 0
while True:
frame = vs.read()
frame = imutils.resize(frame, width=450)
gray = cv2.cvtColor(im, cv2.COLOR_BGR2GRAY)
faces = detector(gray)
face_frame = frame.copy()
for face in faces:
x1 = face.left()
y1 = face.top()
x2 = face.right()
y2 = face.bottom()
cv2.rectangle(face_frame, (x1, y1), (x2, y2), (0, 255, 0), 2)
landmarks = predictor(gray, face)
landmarks = face_utils.shape_to_np(landmarks)
left_blink = blinked(landmarks[36], landmarks[37],
landmarks[38], landmarks[41], landmarks[40], landmarks[39])
right_blink = blinked(landmarks[42], landmarks[43],
landmarks[44], landmarks[47], landmarks[46], landmarks[45])
if(left_blink == 0 or right_blink == 0):
sleep += 1
drowsy = 0
active = 0
if(sleep > 6):
status = "SLEEPING !!!"
color = (255, 0, 0)
GPIO.output(buzzer_pin, GPIO.HIGH)
elif(left_blink == 1 or right_blink == 1):
sleep = 0
active = 0
drowsy += 1
if(drowsy > 6):
status = "Drowsy !"
color = (0, 0, 255)
else:
drowsy = 0
sleep = 0
active += 1
if(active > 6):
status = "Active :)"
color = (0, 255, 0)
cv2.putText(frame, status, (100, 100),
cv2.FONT_HERSHEY_SIMPLEX, 1.2, color, 3)
for n in range(0, 68):
(x, y) = landmarks[n]
cv2.circle(face_frame, (x, y), 1, (255, 255, 255), -1)
cv2.imshow("Frame", frame)
cv2.imshow("Result of detector", face_frame)
key = cv2.waitKey(1)
if key == 27:
break
Please help me! Also, if you think where my code can revised for a better version, please comment to let me know.
