Question/Issue: I am using opencv to read a image, but when I try to use Mat_ object to populate the features array I cannot get the same value that is in the edge impulse studio.
For example: The first pixel the studio gives me 0x646060, but when I calculate my self i get 6578528.
Project ID: 269228
Code:
`#include <stdio.h>
#include <opencv2/core.hpp>
#include <opencv2/imgcodecs.hpp>
#include <opencv2/highgui.hpp>
#include <opencv2/opencv.hpp>
#include
#include “edge-impulse-sdk/classifier/ei_run_classifier.h”
using namespace cv;
using namespace std;
// Callback function declaration
static int get_signal_data(size_t offset, size_t length, float *out_ptr);
// Raw features copied from test sample
float features[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
int main(int argc, char **argv)
// opencv grab image
std::string image_path = samples::findFile(“0.png”);
Mat_ img = imread(image_path, IMREAD_COLOR);
cout << “img:” << img.size() << “\n”;
if (img.empty())
std::cout << "Could not read the image: " << image_path << std::endl;
return 1;
// resize image
Mat_ auxImg;
resize(img, auxImg, Size(96, 96));
Mat_ resizedImg = auxImg.reshape(1, 1);
//debuging
cout << "BGR: " << resizedImg(0,0) << "\n";
cout << "hex: " << (resizedImg(0,0)[2] << 16) + (resizedImg(0,0)[1] << 8) + resizedImg(0,0)[0] << "\n";
signal_t signal; // Wrapper for raw input buffer
ei_impulse_result_t result; // Used to store inference output
EI_IMPULSE_ERROR res; // Return code from inference
for (int i = 0; i < sizeof(features)/sizeof(features[0]); i++)
features[i] = (resizedImg(0,i)[2] << 16) + (resizedImg(0,i)[1] << 8) + resizedImg(0,i)[0];
//cout << i << ": " << features[i] << "\n";
// Calculate the length of the buffer
size_t buf_len = sizeof(features) / sizeof(features[0]);
// Make sure that the length of the buffer matches expected input length
if (buf_len != EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE)
ei_printf("ERROR: The size of the input buffer is not correct.\r\n");
ei_printf("Expected %d items, but got %d\r\n",
EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE,
(int)buf_len);
return 1;
// Assign callback function to fill buffer used for preprocessing/inference
signal.get_data = &get_signal_data;
// Perform DSP pre-processing and inference
res = run_classifier(&signal, &result, false);
// Print return code and how long it took to perform inference
ei_printf("run_classifier returned: %d\r\n", res);
ei_printf("Timing: DSP %d ms, inference %d ms, anomaly %d ms\r\n",
result.timing.dsp,
result.timing.classification,
result.timing.anomaly);
ei_printf("Object detection bounding boxes:\r\n");
for (uint32_t i = 0; i < result.bounding_boxes_count; i++)
if (bb.value == 0)
continue;
ei_printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
bb.label,
bb.value,
bb.x,
bb.y,
bb.width,
bb.height);
return 0;
// Callback: fill a section of the out_ptr buffer when requested
for (size_t i = 0; i < length; i++)
out_ptr[i] = (features + offset)[i];
return EIDSP_OK;
