Hi @rjames  i have run inference on jetson nano previosuly, no wow i try again and i get message “[SER] Could not find any devices connected over serial port”  my /dev0 device it works anywhere else heres what i get when i run
$ gst-device-monitor-1.0
Device found:
name  : Monitor of Built-in Audio Digital Stereo (HDMI)
class : Audio/Source
caps  : audio/x-raw, format=(string){ S16LE, S16BE, F32LE, F32BE, S32LE, S32BE, S24LE, S24BE, S24_32LE, S24_32BE, U8 }, layout=(string)interleaved, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
        audio/x-alaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
        audio/x-mulaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
properties:
	device.description = "Monitor\ of\ Built-in\ Audio\ Digital\ Stereo\ \(HDMI\)"
	device.class = monitor
	alsa.card = 0
	alsa.card_name = tegra-hda
	alsa.long_card_name = "tegra-hda\ at\ 0x70038000\ irq\ 83"
	device.bus_path = platform-70030000.hda
	sysfs.path = /devices/70030000.hda/sound/card0
	device.form_factor = internal
	device.string = 0
	module-udev-detect.discovered = 1
	device.icon_name = audio-card
gst-launch-1.0 pulsesrc device=alsa_output.platform-70030000.hda.hdmi-stereo.monitor ! ...
Device found:
name  : Monitor of Built-in Audio Analog Stereo
properties:
	device.description = "Monitor\ of\ Built-in\ Audio\ Analog\ Stereo"
	alsa.card = 1
	alsa.card_name = tegra-snd-t210ref-mobile-rt565x
	alsa.long_card_name = tegra-snd-t210ref-mobile-rt565x
	device.bus_path = platform-sound
	sysfs.path = /devices/sound/sound/card1
	device.string = 1
gst-launch-1.0 pulsesrc device=alsa_output.platform-sound.analog-stereo.monitor ! ...
Device found:
name  : Built-in Audio Analog Stereo
properties:
	alsa.resolution_bits = 16
	device.api = alsa
	device.class = sound
	alsa.class = generic
	alsa.subclass = generic-mix
	alsa.name = ""
	alsa.id = "ADMAIF1\ CIF\ ADMAIF1-0"
	alsa.subdevice = 0
	alsa.subdevice_name = "subdevice\ \#0"
	alsa.device = 0
	alsa.card = 1
	device.string = front:1
	device.buffering.buffer_size = 32768
	device.buffering.fragment_size = 16384
	device.access_mode = mmap+timer
	device.profile.name = analog-stereo
	device.profile.description = "Analog\ Stereo"
	device.description = "Built-in\ Audio\ Analog\ Stereo"
gst-launch-1.0 pulsesrc device=alsa_input.platform-sound.analog-stereo ! ...
Device found:
name  : Webcam C270 Analog Mono
properties:
	device.api = alsa
	alsa.name = "USB\ Audio"
	alsa.id = "USB\ Audio"
	alsa.subdevice = 0
	alsa.device = 0
	alsa.card = 2
	alsa.card_name = "USB\ Device\ 0x46d:0x825"
	alsa.long_card_name = "USB\ Device\ 0x46d:0x825\ at\ usb-70090000.xusb-2.1\,\ high\ speed"
	alsa.driver_name = snd_usb_audio
	device.bus_path = platform-70090000.xusb-usb-0:2.1:1.2
	sysfs.path = /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.2/sound/card2
	udev.id = usb-046d_0825_5E3631A0-02
	device.bus = usb
	device.vendor.id = 046d
	device.vendor.name = "Logitech\,\ Inc."
	device.product.id = 0825
	device.product.name = "Webcam\ C270"
	device.serial = 046d_0825_5E3631A0
	device.form_factor = webcam
	device.string = hw:2
	device.buffering.buffer_size = 192000
	device.buffering.fragment_size = 96000
	device.profile.name = analog-mono
	device.profile.description = "Analog\ Mono"
	device.description = "Webcam\ C270\ Analog\ Mono"
	alsa.mixer_name = "USB\ Mixer"
	alsa.components = USB046d:0825
	device.icon_name = camera-web-usb
gst-launch-1.0 pulsesrc device=alsa_input.usb-046d_0825_5E3631A0-02.analog-mono ! ...
Device found:
name  : Built-in Audio Digital Stereo (HDMI)
class : Audio/Sink
properties:
	device.api = alsa
	alsa.name = "HDMI\ 0"
	alsa.id = "HDMI\ 0"
	alsa.subdevice = 0
	alsa.device = 3
	alsa.card = 0
	device.string = hdmi:0
	device.buffering.buffer_size = 65536
	device.buffering.fragment_size = 32768
	device.profile.name = hdmi-stereo
	device.profile.description = "Digital\ Stereo\ \(HDMI\)"
	device.description = "Built-in\ Audio\ Digital\ Stereo\ \(HDMI\)"
	alsa.mixer_name = "Nvidia\ Tegra210\ HDMI/DP"
	alsa.components = "HDA:10de0029\,10de0101\,00100100"
gst-launch-1.0 ... ! pulsesink device=alsa_output.platform-70030000.hda.hdmi-stereo
Device found:
class : Audio/Sink
properties:
	device.api = alsa
	alsa.name = ""
	alsa.subdevice = 0
	alsa.device = 0
	alsa.card = 1
gst-launch-1.0 ... ! pulsesink device=alsa_output.platform-sound.analog-stereo
Device found:
name  : UVC Camera (046d:0825)
class : Video/Source
caps  : video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/2, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 25/1, 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        video/x-raw, format=(string)YUY2, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)1280, height=(int)960, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)1184, height=(int)656, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)960, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)1024, height=(int)576, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)960, height=(int)544, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)800, height=(int)600, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)864, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)800, height=(int)448, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)752, height=(int)416, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)640, height=(int)360, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)544, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)432, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)352, height=(int)288, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)320, height=(int)240, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)320, height=(int)176, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)176, height=(int)144, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
        image/jpeg, width=(int)160, height=(int)120, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 25/1, 20/1, 15/1, 10/1, 5/1 };
properties:
	udev-probed = true
	device.bus_path = platform-70090000.xusb-usb-0:2.1:1.0
	sysfs.path = /sys/devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/video4linux/video0
	device.bus = usb
	device.subsystem = video4linux
	device.vendor.name = 046d
	device.product.name = "UVC\ Camera\ \(046d:0825\)"
	device.capabilities = :capture:
	device.api = v4l2
	device.path = /dev/video0
	v4l2.device.driver = uvcvideo
	v4l2.device.card = "UVC\ Camera\ \(046d:0825\)"
	v4l2.device.bus_info = usb-70090000.xusb-2.1
	v4l2.device.version = 264701 (0x000409fd)
	v4l2.device.capabilities = 2216689665 (0x84200001)
	v4l2.device.device_caps = 69206017 (0x04200001)
gst-launch-1.0 v4l2src ! ...
