Hello, Thanks for replying. I had changed it to image classification and trained the model. However, when i am deploying it to my Arduino Portenta H7 using the Arduino IDE 1.8.15 i am getting an error which states Error compiling for board Arduino Portenta H7(M7 core).
Here is the error message…
Arduino: 1.8.15 (Windows 10), Board: “Arduino Portenta H7 (M7 core)”
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\ConvolutionFunctions\arm_convolve_HWC_q7_RGB.c: In function ‘arm_convolve_HWC_q7_RGB’:
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\ConvolutionFunctions\arm_convolve_HWC_q7_RGB.c:125:25: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*__SIMD32(pBuffer) = 0x0;
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\ConvolutionFunctions\arm_convolve_HWC_q7_RGB.c:158:25: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*__SIMD32(pBuffer) = __PKHBT(bottom.word, top.word, 0);
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_nn_mult_q15.c: In function ‘arm_nn_mult_q15’:
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_nn_mult_q15.c:98:9: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*__SIMD32(pDst)++ = __PKHBT(out2, out1, 16);
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_nn_mult_q15.c:99:9: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*__SIMD32(pDst)++ = __PKHBT(out4, out3, 16);
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_nn_mult_q7.c: In function ‘arm_nn_mult_q7’:
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_nn_mult_q7.c:80:9: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*__SIMD32(pDst)++ = __PACKq7(out1, out2, out3, out4);
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_q7_to_q15_reordered_no_shift.c: In function ‘arm_q7_to_q15_reordered_no_shift’:
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_q7_to_q15_reordered_no_shift.c:106:9: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*__SIMD32(pDst)++ = in2;
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\NNSupportFunctions\arm_q7_to_q15_reordered_no_shift.c:107:9: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*__SIMD32(pDst)++ = in1;
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\PoolingFunctions\arm_pool_q7_HWC.c: In function ‘compare_and_replace_if_larger_q7’:
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\PoolingFunctions\arm_pool_q7_HWC.c:78:9: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*__SIMD32(pIn)++ = in.word;
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\PoolingFunctions\arm_pool_q7_HWC.c: In function ‘accumulate_q7_to_q15’:
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\PoolingFunctions\arm_pool_q7_HWC.c:122:9: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*__SIMD32(pCnt)++ = __QADD16(vo1, in);
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\CMSIS\NN\Source\PoolingFunctions\arm_pool_q7_HWC.c:125:9: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
*__SIMD32(pCnt)++ = __QADD16(vo2, in);
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\dsp\image\processing.cpp: In function ‘int ei::image::processing::yuv422_to_rgb888(unsigned char*, const unsigned char*, unsigned int, ei::image::processing::YUV_OPTIONS)’:
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\dsp\image\processing.cpp:73:32: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
for (unsigned int i = 0; i < in_size_pixels; ++i) {
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\tensorflow\lite\core\api\op_resolver.cpp: In function ‘TfLiteStatus tflite::GetRegistrationFromOpCode(const tflite::OperatorCode*, const tflite::OpResolver&, tflite::ErrorReporter*, const TfLiteRegistration**)’:
C:\Users\Shoeb\Documents\Arduino\libraries\Face_Detection_inferencing\src\edge-impulse-sdk\tensorflow\lite\core\api\op_resolver.cpp:34:20: warning: comparison is always false due to limited range of data type [-Wtype-limits]
builtin_code < BuiltinOperator_MIN) {
C:\Users\Shoeb\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.3.1\cores\arduino\USB\USBCDC.cpp: In member function ‘virtual const uint8_t* arduino::USBCDC::configuration_desc(uint8_t)’:
C:\Users\Shoeb\AppData\Local\Arduino15\packages\arduino\hardware\mbed\1.3.1\cores\arduino\USB\USBCDC.cpp:538:35: warning: narrowing conversion of ‘((((arduino::USBCDC*)this)->arduino::USBCDC::extraDescriptor != 0) ? 5 : 0)’ from ‘int’ to ‘uint8_t {aka unsigned char}’ inside { } [-Wnarrowing]
(extraDescriptor != NULL) ? 0x5 : 0x0, // iInterface
c:/users/shoeb/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/…/lib/gcc/arm-none-eabi/7.2.1/…/…/…/…/arm-none-eabi/bin/ld.exe: C:\Users\Shoeb\AppData\Local\Temp\arduino_build_56221/static_buffer1.ino.elf section .text' will not fit in region FLASH’
c:/users/shoeb/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/…/lib/gcc/arm-none-eabi/7.2.1/…/…/…/…/arm-none-eabi/bin/ld.exe: region `FLASH’ overflowed by 4460 bytes
exit status 1
Error compiling for board Arduino Portenta H7 (M7 core).
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
