Cannot apply labels through CLI or Interface
Hi there,
I recently went through continuous-gestures on Arduino ble33 Sense CLI.
A label was added before starting each 10sec training session however the label was not applied/saved.
Even after manually editing the labels they do not save to the acquired data.
Screen Shot 2021-07-01 at 9.09.05 PM
The labelling queue also serves an broken image with a 500 error. Not sure if this is strict for vision labeling?
“Failed to load resource: the server responded with a status of 500”
Any help labeling my data would be appreciated,
Cheers,
Hi @somenice,
The labelling is indeed for vision/object detection only.
Regarding your labelling issue, which browser are you using?
Thanks @aurel I believe I set up the project initially for vision image classification but then then switched to accelerometer data.
Changing the labeling method on the project to “One label per data item” has now labeled all the samples correctly…
Thanks again for the reply
