Can some one tell me whats wrong with my csv file?
Failed to upload up_down.46dad8c2ffb7.csv: Could not parse this CSV file, go to https://studio.edgeimpulse.com/studio/337641/upload/csv to help us import this CSV file. (Error message: For CSV files without a timestamp column, need exactly one line with values (but found 840))
Here’s how my file look like
Timestamp,accX,accY,accZ
2,6.92,-26.16,92.71
13,8.08,-26.16,90.02
25,2.69,-26.16,87.32
37,1.15,-25.77,82.71
49,1.15,-22.70,75.40
10069,13.08,0.77,111.56
There are total 840 lines
I am using Windows 11.
Hi @Aniket_26,
The timestamp delta should be constant between lines. Seems like if it’s set to 1 on the first line it should work (delta 12 between timestamps). You can also rename timestamp to lower case but it should not be the reason why it fails.
Thank you for your reply aurel, I just changed the Timestamp to lowercase and it worked.
