Can i run my edge impusle model to STM32N6570-DK
I want to run my Edge Impulse model on STM32N6570-DK
Is this possible? If possible, what should I do?
Edge AI Hardware > MCU + AI accelerators
STMicroelectronics STM32N6570-DK
I’m going to use the method introduced in this section
but there is a below sentence in this section
and I have one more question
What is the difference between using
Run reference > Cube.MX CMSIS-PACK
and using
Edge AI Hardware > MCU + AI accelerators > STMicroelectronics STM32N6570-DK
“At this time only Object Detection projects using FOMO or YOLOV5 are support with the N6 on Edge Impulse.”
so I’m not sure if I can use this method because there’s a sentence like this.
and
[Provide the project ID]
593258
Hi @aither
Cube.MX CMSIS-PACK is a generic package for all open-CMSIS supported hardware by STM where the other is a sample firmware specifically created for the STM32N6570-DK that you can use for testing, and you can also take the open source code to build your own project from the firmware as a base.
Hope this helps
@Arjan @ei_francesco
STMicroelectronics STM32N6570-DK | Edge Impulse Documentation
Correct,
The Cube.MX CMSIS-PACK code doesn’t utilize the NPU on the STM32N6570.
