Camera init failed with error 0xffffffff
I’m trying to use the ESP32 camera from my Edge Impulse model - using the Arduino libraries - with a XIAO ESP32S3 Sense, but now I’m getting the following error when initializing:
Edge Impulse Inferencing Demo
E (1022) cam_hal: cam_dma_config(300): frame buffer malloc failed
E (1023) cam_hal: cam_config(384): cam_dma_config failed
E (1023) camera: Camera config failed with error 0xffffffff
Failed to initialize Camera!
It works well when using the camera webserver example.
Just trying and example
Hi @feiticeir0
By default, the esp32-camera sketch is configured to work with the ESP-EYE. This step is included in our Arduino Library doc:
#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_AI_THINKER // Has PSRAM
by
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
You can find other camera model pin definitions here.
For the CAMERA_MODEL_XIAO_ESP32S3, the pin definitions in the camera initialization code are as follows:
  • PWDN_GPIO_NUM: -1
  • RESET_GPIO_NUM: -1
  • XCLK_GPIO_NUM: 10
  • SIOD_GPIO_NUM: 40
  • SIOC_GPIO_NUM: 39
  • Y9_GPIO_NUM: 48
  • Y8_GPIO_NUM: 11
  • Y7_GPIO_NUM: 12
  • Y6_GPIO_NUM: 14
  • Y5_GPIO_NUM: 16
  • Y4_GPIO_NUM: 18
  • Y3_GPIO_NUM: 17
  • Y2_GPIO_NUM: 15
  • VSYNC_GPIO_NUM: 38
  • HREF_GPIO_NUM: 47
  • PCLK_GPIO_NUM: 13
Hi @Eoin .
I did try those pins - I got them from the camera_pins.h .
And still no luck.
I have 2 of these XIAO and both fail with the same error:
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0x2b (SPI_FAST_FLASH_BOOT)
Saved PC:0x42030b5a
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a80
entry 0x403c98d0
E (109) cam_hal: cam_dma_config(300): frame buffer malloc failed
E (110) cam_hal: cam_config(384): cam_dma_config failed
E (110) camera: Camera config failed with error 0xffffffff
Don’t know what to do here… :pensive:
I finally solve this.
Going through the Arduino IDE option tools for the XIAO_ESP32S3, I found out that the option PSRAM: “OPI PSRAM” was disabled.
As soon that I enabled that option and uploaded the sketch, no more error and inference was going great.
Been struggling with this issue for several hours… This solved my problem, thanks!
Thanks man it worked!
