Calculating RAM Usage
Hello…
I want to calculate RAM Usage of my models after their deployment on the hardware (Nano 33 BLE Sense). However i’m not sure how to…
https://os.mbed.com/blog/entry/Tracking-memory-usage-with-Mbed-OS/
I am using above method to trace the memory. However i get 4 values…
Current Heap
Reserved Heap
Max Size stack
Reserved stack
What values out of them would actually relate to my current RAM consumption? For example on Edge impulse i’m getting an estimate of 16KBs… so what values out of them would make something similar to this? or true values?
I know heap is related to the global values and stack to locals somehow… but i don’t know much!
I am really looking forward to some answers…
Hello @rida,
Can you share your custom code where you print the memory info?
I’m not using any custom code… i’m just trying it on audio classification example (not continuous).
I’m printing memory info before and after inference start… then before and after running classifier. The readings are constant around 43K for all the models… and at every point of code.
I’m assuming that’s just the heap assigned to the recorded raw samples…
The NN classifier frees all the heap once it classifies the sample. So i can’ t track it…
Only the tf arena size is arounfd 13 K according to the cpp file of trained model… (which is close to 16KB)
Indeed, you’ll need to check the memory from inside these functions. It depends on how you compile the SDK (EON compiler, quantized version, unoptimized version).
Search for this file in the SDK, you’ll have a better understanding:
edge-impulse-sdk → classifier → ei_run_classifier.h
and then for the non-continuous, search for the function run_nn_inference
You can also check the DSP if you’d like.
One other question… when a code uploads to arduino and it says for example…
Global variables use 39% of the dynamic memory… does it also have the tensor arena in it already? or is it assigned only when running classifier?
@rida What do you mean when referring to the tensor arena? if you are referring to the model, then it is part of the binary you are flashing to the device.
Also global variables are usually stored in the data section. Heap is only a temporary data structure you get when you request a specific size of the memory.
If you are referring to the sensor data, then the feature array should be allocated from the heap when the data is read from the sensor.
If you are interested we provide the firmware as open source please have a look here:
