C++ library example on ESP32 fails to compile
The example on C++ inference for ESP32 provided in the documentation does not work
Running an example to test a model in ESP32 using a C++ library
Summary:
The compilation fails with the following error:
/var/folders/5j/sw69jdcj6_z2f3018pym4_pc0000gn/T//ccDQiCqr.s: Assembler messages:
/var/folders/5j/sw69jdcj6_z2f3018pym4_pc0000gn/T//ccDQiCqr.s:11: Error: file not found: tflite-model/tflite_learn_22.tflite
Steps to Reproduce:
  1. Followed the instructions on On your Espressif ESP-EYE (ESP32) development board | Edge Impulse Documentation
  2. Paste example features from live classification on Edge Impulse
  3. Build
Expected Results:
The project compiles and runs
Actual Results:
Compilation error
  • [X] Always
  • Platform: ESP32
  • Build Environment Details: ESP-IDF v5.5
  • OS Version: Mac OS 14
Hi, @lbedogni !
Sounds like some cached files from the last build? It might happen if you first compile one project, then delete the model, paste another one and don’t run clean build.
Try
idf.py fullclean
Hi @AIWintermuteAI , I already tried but I end up having the same error
I don’t know what happened, but I performed fullclean and build several times and suddenly it started working.
