Anyone have a small snippet of Python that would allow me to upload images in bulk via the Ingestion Service?
ChatGPT says this should work, but, I am not convinced:
Can anyone give me a correct snippet, please and thanks in advance!
import os
import requests
# Set the directory to parse
directory = 'my/data/directory'
# Iterate through the subdirectories in the given directory
for subdir in os.listdir(directory):
subdir_path = os.path.join(directory, subdir)
if os.path.isdir(subdir_path):
label = subdir
# Iterate through the files in the subdirectory
for file in os.listdir(subdir_path):
file_path = os.path.join(subdir_path, file)
if os.path.isfile(file_path):
with open(file, 'r') as file:
res = requests.post(url='https://ingestion.edgeimpulse.com/api/training/data',
data=file,
headers={
'Content-Type': 'image/jpeg',
'x-file-name': file,
'x-label': label,
'x-api-key': 'ei_xxxxxxxxx'
if (res.status_code == 200):
print('Uploaded file to Edge Impulse', res.status_code, res.content)
else:
print('Failed to upload file to Edge Impulse', res.status_code, res.content)
No doubt Jan is correct but one must manually create the files array (based on the examples at the link given):
files = [
('data', open('one.png', 'rb')),
('data', open('two.png', 'rb')),
The original post code in question goes and gets all files pointed to without any manual array manipulation. A use case would be files automatically added to a post production release training set for example when an inference gave a very low prediction rate.
The code as-was does not work.
- The code uses the legacy
data endpoint so I did not try and verify that endpoint.
- The code is trying to stick too much in the
header{}.
- Most of the code is correct.
- Using the
files endpoint the code need to be modified as follows:
with open(file_path, 'r') as file: β Change βfileβ to "file_path"
res = requests.post(url='https://ingestion.edgeimpulse.com/api/training/files' β Change the endpoint βdataβ to "files"
REM OUT β data=file_path, <ββdataβ is not used. You must use βfilesβ.
headers={
REM OUT β 'Content-Type': 'image/jpeg', This gets included in files{}
REM OUT β 'x-file-name': file_path, This gets included in files{}
'x-label': label,
'x-api-key': 'ei_xxxxxxx},
files = { 'data': (os.path.basename(file_path), open(file_path, 'rb'), 'image/jpeg') }) β Add this line
For those that want to cut-n-paste:
The folder structure is:
images-|
--ClassName01-|
File01
File02
Filenn
--ClassName02-|
File01
File02
Filenn
import os
import requests
directory = 'my/images/'
# Iterate through the sub-directories in the given directory
label = subdir
res = requests.post(url='https://ingestion.edgeimpulse.com/api/training/files',
headers={
'x-label': label,
else:
I knew ChatGPT could not be trusted, ha! Thanks @MMarcial!
