Build a model that classifies issues and resolution data and provide recommendation
I have data set that involves text and numeric characters in most of the column but getting the following message even after going through the CSV wizard.
Uploading 1 file…
[1/1] Failed to upload Door_Issue (1).csv: Failed to parse CSV file: Row 1, column 10 should be numeric, but is not
[Provide the project ID]
I am trying to build a model that would read the data that contains text and numeric values and offer suggestion based on previous actions taken.
  1. [Step 1]
  2. [Step 2]
  3. [Step 3]
be able to successfully upload data
Uploading 1 file…
  • [ ] Always
Hello @AkilanSakthi first of all welcome to the Edge Impulse community!
Could you please share more details related with your CSV? is the text data convertible into numbers (e.g. UP=1, DOWN=2, etc) or it’s more complex?
Feel free to share more information to try to help you more!
Its more complex. Its column of issues and what was performed to fix it in the next column(consist of text and numbers). I want to input multiple issues but i am trying to build a model that will provide a response to my problem based on prior resolution database.
Could you please share an example of your CSV to try to replicate @AkilanSakthi ?
