Auto Labeler keeps failing.
Project ID: 337134
Every time I run the auto labeler, I get this error:
Creating job... OK (ID: 15240975)
Scheduling job in cluster...
Container image pulled!
Job started
[1/4] Downloading files...
Syncing 16146 files...
[    1/16146] Syncing files...
[16146/16146] Syncing files... (0 MB downloaded)
Done. Success: 16146 Failed: 0
[1/4] Downloading files OK
[2/4] Creating segments...
Creating segments from 16146 images (cuda)...
[  489/16146] Creating segments...
  File "segment-dataset.py", line 115, in <module>
    masks = mask_generator.generate(source_image)
  File "/app/.venv/lib/python3.8/site-packages/torch/utils/_contextlib.py", line 115, in decorate_context
    return func(*args, **kwargs)
  File "/app/.venv/lib/python3.8/site-packages/segment_anything/automatic_mask_generator.py", line 163, in generate
    mask_data = self._generate_masks(image)
  File "/app/.venv/lib/python3.8/site-packages/segment_anything/automatic_mask_generator.py", line 206, in _generate_masks
    crop_data = self._process_crop(image, crop_box, layer_idx, orig_size)
  File "/app/.venv/lib/python3.8/site-packages/segment_anything/automatic_mask_generator.py", line 245, in _process_crop
    batch_data = self._process_batch(points, cropped_im_size, crop_box, orig_size)
  File "/app/.venv/lib/python3.8/site-packages/segment_anything/automatic_mask_generator.py", line 297, in _process_batch
    data.filter(keep_mask)
  File "/app/.venv/lib/python3.8/site-packages/segment_anything/utils/amg.py", line 49, in filter
    self._stats[k] = v[torch.as_tensor(keep, device=v.device)]
torch.cuda.OutOfMemoryError: CUDA out of memory. Tried to allocate 5.68 GiB (GPU 0; 14.76 GiB total capacity; 9.01 GiB already allocated; 4.82 GiB free; 9.05 GiB reserved in total by PyTorch) If reserved memory is >> allocated memory try setting max_split_size_mb to avoid fragmentation.  See documentation for Memory Management and PYTORCH_CUDA_ALLOC_CONF
Does anyone know if it’s possible to fix this?
