I’m editing the file audio.py that is under the examples folder, however, I can’t see the changes reflected when running the classify.py. Am I editing the correct file? I even just added a print statement but it wasn’t printed.
Hi @Aisha you need to rebuild / reinstall the Python library after every change, e.g. via:
python3 setup.py install
Very annoying, but I’m not sure if there’s an easier way.
