In this audio classification project, I can build a firmware specifically for the Arduino Nano 33 BLE Sense and run it without any problems. However, when I export as an Arduino library and run the continuous microphone sketch, I get the following errors:
When EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW == 3 (Default):
When EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW == 2:
Mbed OS seems to fail almost instantly, orange LED blinks in SOS pattern and IDE freezes when I try to open the serial monitor -
When EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW == 1:
I tried making the DSP process in my impulse less memory- and processor-intensive and then retrained but the errors did not change.
Arduino core version: 1.3.2
EDIT: The non-continuous sketch works well, even without the two second delay.
Thanks.
