Are LSTM models deployable using Python SDK?
I am trying to deploy a Pytorch model using the LSTM layer. I converted the model to Onnx and deploy it to the Python SDK. This is the error that I got:
Trying conversion using onnx2tf...
e[31mERROR:e[0m LSTM OP is not yet implemented.
Conversion using onnx2tf failed, trying conversion using onnx-tf...
ERROR: Could not load albumentations library. This is a known issue during unit tests on M1 Macs (#3880) and will prevent object detection augmentation from working.
Original error message:
No module named 'albumentations'
File "/app/convert-via-tf-onnx.py", line 68, in <module>
ei_tensorflow.onnx.conversion.onnx_to_tflite(args.onnx_file, file_float32, file_int8,
File "/app/./resources/libraries/ei_tensorflow/onnx/conversion.py", line 96, in onnx_to_tflite
tf_rep.export_graph(tf_model_path)
File "/usr/local/lib/python3.10/dist-packages/onnx_tf/backend_rep.py", line 143, in export_graph
signatures=self.tf_module.__call__.get_concrete_function(
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/eager/polymorphic_function/polymorphic_function.py", line 1215, in get_concrete_function
concrete = self._get_concrete_function_garbage_collected(*args, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/eager/polymorphic_function/polymorphic_function.py", line 1195, in _get_concrete_function_garbage_collected
self._initialize(args, kwargs, add_initializers_to=initializers)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/eager/polymorphic_function/polymorphic_function.py", line 749, in _initialize
self._variable_creation_fn # pylint: disable=protected-access
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/eager/polymorphic_function/tracing_compiler.py", line 162, in _get_concrete_function_internal_garbage_collected
concrete_function, _ = self._maybe_define_concrete_function(args, kwargs)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/eager/polymorphic_function/tracing_compiler.py", line 157, in _maybe_define_concrete_function
return self._maybe_define_function(args, kwargs)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/eager/polymorphic_function/tracing_compiler.py", line 360, in _maybe_define_function
concrete_function = self._create_concrete_function(args, kwargs)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/eager/polymorphic_function/tracing_compiler.py", line 284, in _create_concrete_function
func_graph_module.func_graph_from_py_func(
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/framework/func_graph.py", line 1283, in func_graph_from_py_func
func_outputs = python_func(*func_args, **func_kwargs)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/eager/polymorphic_function/polymorphic_function.py", line 645, in wrapped_fn
out = weak_wrapped_fn().__wrapped__(*args, **kwds)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/eager/polymorphic_function/tracing_compiler.py", line 445, in bound_method_wrapper
return wrapped_fn(*args, **kwargs)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/framework/func_graph.py", line 1269, in autograph_handler
raise e.ag_error_metadata.to_exception(e)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/framework/func_graph.py", line 1258, in autograph_handler
return autograph.converted_call(
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/autograph/impl/api.py", line 439, in converted_call
result = converted_f(*effective_args, **kwargs)
File "/tmp/__autograph_generated_file6oxxwyd5.py", line 30, in tf____call__
ag__.for_stmt(ag__.ld(self).graph_def.node, None, loop_body, get_state, set_state, (), {'iterate_names': 'node'})
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/autograph/operators/control_flow.py", line 463, in for_stmt
_py_for_stmt(iter_, extra_test, body, None, None)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/autograph/operators/control_flow.py", line 512, in _py_for_stmt
body(target)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/autograph/operators/control_flow.py", line 478, in protected_body
original_body(protected_iter)
File "/tmp/__autograph_generated_file6oxxwyd5.py", line 23, in loop_body
output_ops = ag__.converted_call(ag__.ld(self).backend._onnx_node_to_tensorflow_op, (ag__.ld(onnx_node), ag__.ld(tensor_dict), ag__.ld(self).handlers), dict(opset=ag__.ld(self).opset, strict=ag__.ld(self).strict), fscope)
File "/tmp/__autograph_generated_fileh0or0oq3.py", line 62, in tf___onnx_node_to_tensorflow_op
ag__.if_stmt(ag__.ld(handlers), if_body_1, else_body_1, get_state_1, set_state_1, ('do_return', 'retval_'), 2)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/autograph/operators/control_flow.py", line 1363, in if_stmt
_py_if_stmt(cond, body, orelse)
File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/autograph/operators/control_flow.py", line 1416, in _py_if_stmt
return body() if cond else orelse()
File "/tmp/__autograph_generated_fileh0or0oq3.py", line 56, in if_body_1
ag__.if_stmt(ag__.ld(handler), if_body, else_body, get_state, set_state, ('do_return', 'retval_'), 2)
File "/tmp/__autograph_generated_fileh0or0oq3.py", line 48, in if_body
retval_ = ag__.converted_call(ag__.ld(handler).handle, (ag__.ld(node),), dict(tensor_dict=ag__.ld(tensor_dict), strict=ag__.ld(strict)), fscope)
File "/tmp/__autograph_generated_filewlu2cz77.py", line 41, in tf__handle
ag__.if_stmt(ag__.ld(ver_handle), if_body, else_body, get_state, set_state, ('do_return', 'retval_'), 2)
File "/tmp/__autograph_generated_filewlu2cz77.py", line 40, in else_body
raise ag__.converted_call(ag__.ld(BackendIsNotSupposedToImplementIt), (ag__.converted_call('{} version {} is not implemented.'.format, (ag__.ld(node).op_type, ag__.ld(cls).SINCE_VERSION), None, fscope),), None, fscope)
onnx.backend.test.runner.BackendIsNotSupposedToImplementIt: in user code:
File "/usr/local/lib/python3.10/dist-packages/onnx_tf/backend_tf_module.py", line 99, in __call__ *
output_ops = self.backend._onnx_node_to_tensorflow_op(onnx_node,
File "/usr/local/lib/python3.10/dist-packages/onnx_tf/backend.py", line 347, in _onnx_node_to_tensorflow_op *
return handler.handle(node, tensor_dict=tensor_dict, strict=strict)
File "/usr/local/lib/python3.10/dist-packages/onnx_tf/handlers/handler.py", line 61, in handle *
raise BackendIsNotSupposedToImplementIt("{} version {} is not implemented.".format(node.op_type, cls.SINCE_VERSION))
BackendIsNotSupposedToImplementIt: Unsqueeze version 13 is not implemented.
Are LSTM layers not supported yet? and what do you suggest as a solution?
Ahmed,
