Arduino object detection code doesn't compile
Question/Issue: I did an object detection model for my ESP32-Cam and I’m trying to run the code as an Arduino Library, but when I try to verify it, the IDE can’t resolve the libraries, well it’s not this but it takes so long to find and apply the correct library that it returns a ping timeout.
I don’t know what to do anymore, I tried to compile it in the Arduino IDE and in VS Code, did the inclusion of the custom library Edge Impulse gives when building the project, I’m literally using the example code and this is just a test, I am building a much larger project, so I can’t continue with it without getting this one to work first.
Project ID: 288498
Context/Use case: The error i get in the Arduino IDE is just “ping timeout”. This is the error message I’m getting in VS Code:
Sketch uses 472129 bytes (15%) of program storage space. Maximum is 3145728 bytes.
Global variables use 34224 bytes (10%) of dynamic memory, leaving 293456 bytes for local variables. Maximum is 327680 bytes.
IntelliSense configuration updated. To manually rebuild your IntelliSense configuration run "Ctrl+Alt+I"
[Done] Verifying sketch 'espCam-cube-piram.ino'
I made some little modifications on the code, but only at the beggining of it, to keep it more clean for me, but here it is:
#include <LuizSV11-project-1_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#if defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
#else
#error "Camera model not selected"
#endif
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS           320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS           240
#define EI_CAMERA_FRAME_BYTE_SIZE                 3
    .pin_pwdn = PWDN_GPIO_NUM,
    .pin_reset = RESET_GPIO_NUM,
    .pin_xclk = XCLK_GPIO_NUM,
    .pin_d7 = Y9_GPIO_NUM,
    .pin_d6 = Y8_GPIO_NUM,
    .pin_d5 = Y7_GPIO_NUM,
    .pin_d4 = Y6_GPIO_NUM,
    .pin_d3 = Y5_GPIO_NUM,
    .pin_d2 = Y4_GPIO_NUM,
    .pin_d1 = Y3_GPIO_NUM,
    .pin_d0 = Y2_GPIO_NUM,
    .pin_vsync = VSYNC_GPIO_NUM,
    .pin_href = HREF_GPIO_NUM,
    .pin_pclk = PCLK_GPIO_NUM,
    .xclk_freq_hz = 20000000,
    .ledc_timer = LEDC_TIMER_0,
    .frame_size = FRAMESIZE_QVGA,    //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
    .fb_count = 1,       //if more than one, i2s runs in continuous mode. Use only with JPEG
bool ei_camera_init(void);
void ei_camera_deinit(void);
void setup()
    Serial.begin(115200);
    while (!Serial);
    else {
    ei_sleep(2000);
* @param[in]  debug  Get debug info if true
void loop()
        return;
    if(snapshot_buf == nullptr) {
        return;
    ei::signal_t signal;
        free(snapshot_buf);
        return;
    // Run the classifier
    if (err != EI_IMPULSE_OK) {
        return;
    // print the predictions
        if (bb.value == 0) {
            continue;
        ei_printf("    %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n", bb.label, bb.value, bb.x, bb.y, bb.width, bb.height);
    if (!bb_found) {
        ei_printf("    No objects found\n");
#else
        ei_printf("    %s: %.5f\n", result.classification[ix].label,
#endif
#endif
    free(snapshot_buf);
 * @brief   Setup image sensor & start streaming
 * @retval  false if initialisation failed
bool ei_camera_init(void) {
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
    //initialize the camera
    if (err != ESP_OK) {
      return false;
    s->set_vflip(s, 1);
    s->set_hmirror(s, 1);
    s->set_vflip(s, 1);
    s->set_awb_gain(s, 1);
#endif
    is_initialised = true;
    return true;
 * @brief      Stop streaming of sensor data
void ei_camera_deinit(void) {
    //deinitialize the camera
    if (err != ESP_OK)
        ei_printf("Camera deinit failed\n");
        return;
    return;
 * @brief      Capture, rescale and crop image
 * @param[in]  img_width     width of output image
 * @param[in]  img_height    height of output image
 * @param[in]  out_buf       pointer to store output image, NULL may be used
 *                           if ei_camera_frame_buffer is to be used for capture and resize/cropping.
 * @retval     false if not initialised, image captured, rescaled or cropped failed
    bool do_resize = false;
    if (!is_initialised) {
        return false;
    if (!fb) {
        return false;
   esp_camera_fb_return(fb);
   if(!converted){
       ei_printf("Conversion failed\n");
       return false;
        do_resize = true;
    if (do_resize) {
        out_buf,
        EI_CAMERA_RAW_FRAME_BUFFER_COLS,
        out_buf,
        img_width,
        img_height);
    return true;
    size_t pixel_ix = offset * 3;
    size_t pixels_left = length;
    size_t out_ptr_ix = 0;
    while (pixels_left != 0) {
        out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix + 2];
        // go to the next pixel
        out_ptr_ix++;
        pixel_ix+=3;
        pixels_left--;
    // and done!
    return 0;
#endif
I hope this is suficient for someone to help me and sorry for any english mistakes.
I was able to compile the INO code above. I replaced your library with mine:
//#include <LuizSV11-project-1_inferencing.h>
#include <Cup_inferencing.h>
I chose board ESP Wrover Module since I have an ESP-EYE (not a CAM).
  • What board are you compiling for in the Arduino IDE?
  • I don’t understand ping timeout…are you using the online Arduino IDE?
Once you get it to compile…
What CAM board do you have:
  • ESP_CAM,
  • ESPS2_CAM, or
  • ESPS3_CAM?
So you’ll need to change the line:
with one of these
#define CAMERA_MODEL_ESP32_CAM_BOARD
#define CAMERA_MODEL_ESP32S3_CAM_LCD
#define CAMERA_MODEL_ESP32S2_CAM_BOARD
#define CAMERA_MODEL_ESP32S3_EYE
and then swap out this code with the pin definitions for your camera:
 <<< This code is found in camera_pins.h referenced on line #8 in your code above. >>>
#endif
