Arduino Nicla Vision flashing problem
Hi there - Im trying to flash EdgeImpulse firmware to Nicla vision and after running
flash_mac.command on macOS i get:
Platform arduino:mbed_nicla@3.2.0 installed
Installing Arduino Mbed core OK
Finding Arduino Nicla Vision…
Finding Arduino Nicla Vision OK
Flashing board…
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x68 pc=0x100859a79]
goroutine 1 [running]:
github.com/arduino/arduino-cli/arduino/sketch.(*Sketch).GetDefaultFQBN(...)
Flashing failed. Here are some options:
If your error is ‘incorrect FQBN’ you’ll need to upgrade the Arduino core via:
$ arduino-cli core update-index
$ arduino-cli core install arduino:mbed_nicla@3.2.0
Otherwise, double tap the RESET button to load the bootloader and try again
Saving session…
…copying shared history…
…saving history…truncating history files…
…completed
I could not find similar case anywhere and will appreciate any help,
Regards!
Okay, that is likely not related to our firmware.
Can you flash Blink sketch to Nicla Vision normally?
OS, Arduino versions?
I am getting same problem also.
arduino-nicla-vision_firmware_edge_impulse/flash_mac.command ; exit;
You’re using an untested version of Arduino CLI, this might cause issues (found: 0.34.1, expected: 0.18.x)
Finding Arduino Mbed core…
Finding Arduino Mbed OK
Flashing board…
[signal SIGSEGV: segmentation violation code=0x2 addr=0x68 pc=0x101297904]
Arduino Nicla Vision Bootloader uploaded correctly using Arduino IDE.
Using M1 Mac OS 13.4.1 Ventura
Using OpenMV IDE 4.0.1
