So I’m attempting to include gyro data from the IMU in the 33 BLE firmware(https://github.com/edgeimpulse/firmware-arduino-nano-33-ble-sense), most current master(e380fbfd20e560cf9bac721b4008d062fdff05a8). After data acquisition is started, it never completes and I think it is due to the firmware hanging. Below are my changes to increase the axis count to 6, and it looks like there was some preliminary effort to make this functionality available already. I converted the units to rad and not rad per sec, because rad is a valid SenML identifier, where the previous “dps” isn’t according to the validator in the firmware. Did I miss something? I’m assuming I must have.
diff --git a/src/sensors/ei_inertialsensor.cpp b/src/sensors/ei_inertialsensor.cpp
index 3695097..dc0ed50 100644
--- a/src/sensors/ei_inertialsensor.cpp
+++ b/src/sensors/ei_inertialsensor.cpp
@@ -20,6 +20,7 @@ using namespace events;
+#define CONVERT_degperS_TO_radperS 0.01745329252f
extern void ei_printf(const char *format, ...);
@@ -56,6 +57,10 @@ void ei_inertial_read_data(void)
#if(N_AXIS_SAMPLED == 6)
if (IMU.gyroscopeAvailable()) {
IMU.readGyroscope(imu_data[3], imu_data[4], imu_data[5]);
+ imu_data[3] *= CONVERT_degperS_TO_radperS;
+ imu_data[4] *= CONVERT_degperS_TO_radperS;
+ imu_data[5] *= CONVERT_degperS_TO_radperS;
#endif
@@ -85,7 +90,7 @@ bool ei_inertial_setup_data_sampling(void)
// Check available sample size before sampling for the selected frequency
uint32_t requested_bytes = ceil((ei_config_get_config()->sample_length_ms / ei_config_get_config()->sample_interval_ms) * SIZEOF_N_AXIS_SAMPLED * 2);
if(requested_bytes > available_bytes) {
- ei_printf("ERR: Sample length is too long. Maximum allowed is %ims at %.1fHz.\r\n",
+ ei_printf("ERR: Sample length is too long. Maximum allowed is %ims at %.1fHz.\r\n",
(int)floor(available_bytes / ((SIZEOF_N_AXIS_SAMPLED * 2) / ei_config_get_config()->sample_interval_ms)),
(1000 / ei_config_get_config()->sample_interval_ms));
return false;
@@ -100,8 +105,8 @@ bool ei_inertial_setup_data_sampling(void)
ei_config_get_config()->sample_interval_ms,
// The axes which you'll use. The units field needs to comply to SenML units (see https://www.iana.org/assignments/senml/senml.xhtml)
{ { "accX", "m/s2" }, { "accY", "m/s2" }, { "accZ", "m/s2" },
- /*{ "gyrX", "dps" }, { "gyrY", "dps" }, { "gyrZ", "dps" } */},
+ { "gyrX", "rad" }, { "gyrY", "rad" }, { "gyrZ", "rad" } },
return ei_sampler_start_sampling(&payload, SIZEOF_N_AXIS_SAMPLED);
\ No newline at end of file
diff --git a/src/sensors/ei_inertialsensor.h b/src/sensors/ei_inertialsensor.h
index db19e18..2f77b71 100644
--- a/src/sensors/ei_inertialsensor.h
+++ b/src/sensors/ei_inertialsensor.h
@@ -7,7 +7,7 @@
/** Number of axis used and sample data format */
typedef float sample_format_t;
-#define N_AXIS_SAMPLED 3
+#define N_AXIS_SAMPLED 6
#define SIZEOF_N_AXIS_SAMPLED (sizeof(sample_format_t) * N_AXIS_SAMPLED)
@@ -16,4 +16,4 @@ bool ei_inertial_init(void);
bool ei_inertial_sample_start(sampler_callback callback, float sample_interval_ms);
bool ei_inertial_setup_data_sampling(void);
-#endif
+#endif
I am aware of the data forwarder and I suppose I could write a set of scripts to use that but I would prefer to stick with the autostart and other functionality available with the standard firmware, as the task I’m trying to classify requires a bit of concentration to carry out and I’m already under a sampling time-crunch.
