when i flash edge impulse to arduino board it works but then get the following error: ERR: Frequency is 44100 but can not be higher then 16000Hz
Can you elaborate more on how you are flashing the device and what firmware are you using?
and what version of the Arduino nano33 are you using?
Omar
Thanks so much, i followed these instructions https://docs.edgeimpulse.com/docs/development-platforms/officially-supported-mcu-targets/arduino-nano-33-ble-sense
the board is nanno33 sense rev2 board ble
here is the full message in the terminal: Edge Impulse impulse runner v1.17.3
[SER] Connecting to /dev/tty.usbmodem11201
Failed to parse snapshot line [ ]
[SER] Retrieved configuration
[SER] Device is running AT command version 1.8.0
[SER] Started inferencing, press CTRL+C to stop…
LSE
