Hello
Does edge impulse support Arduino library for ESP32?
I use Arduino IDE 1.8.19 with ESP32 board package so did deploy my model for Arduino library. I added the zip file to the library manager in the Arduino IDE and had to define absolute location for some header files. I try to compile the example code static buffer but get so many compile errors. list of a few of them as follows:
\edge-impulse-sdk\dsp\numpy_types.h:387:10: error: ‘function’ in namespace ‘std’ does not name a template type
std::function<int(size_t offset, size_t length, float *out_ptr)> get_data;
\edge-impulse-sdk\CMSIS\DSP\Include\arm_common_tables.h:75:51: error: size of array ‘twiddleCoefF64_2048’ is too large
extern const uint64_t twiddleCoefF64_2048[4096];
\edge-impulse-sdk\dsp\numpy.hpp: In static member function ‘static void ei::numpy::transpose_in_place(ei::matrix_t*)’:
C:\Arduino\static-test\edge-impulse-sdk\dsp\numpy.hpp:346:14: error: ‘vector’ is not a member of ‘std’
std::vector done(size+1,false);
