#include <gestures_inference.h>
#include <Arduino_LSM9DS1.h>
static signed short redPin = 22;
static signed short greenPin = 23;
static signed short bluePin = 24;
static signed short classificationNone = EI_CLASSIFIER_LABEL_COUNT;
static bool debug_nn = true; // Set this to true to see e.g. features generated from the raw signal
void setup()
Serial.begin(9600);
if (!IMU.begin()) {
ei_printf("Failed to initialize IMU!\r\n");
else {
ei_printf("IMU initialized\r\n");
return;
void ei_printf(const char *format, …) {
va_list args;
va_start(args, format);
va_end(args);
if (r > 0) {Serial.write(print_buf);}
void loop()
ei_printf("\nStarting inferencing in 2 seconds…\n");
ei_printf(“Sampling…\n”);
IMU.readAcceleration(buffer[ix], buffer[ix + 1], buffer[ix + 2]);
buffer[ix + 1] *= CONVERT_G_TO_MS2;
buffer[ix + 2] *= CONVERT_G_TO_MS2;
signal_t signal;
if (err != 0) {
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
if (result.classification[ix].value > 0.7) {
if(ix==0){
analogWrite(22,0);
analogWrite(23,255);
analogWrite(24,255);
else if(ix==1){
analogWrite(22,255);
analogWrite(23,0);
else if(ix==2){
analogWrite(24,0);
else{
analogWrite(22,0);
analogWrite(23,0);
#endif
#error “Invalid model for current sensor”
#endif
