Tizi
March 21, 2024, 3:11pm
#1
I’m new to Edge Impulse and this is my first project. If you need more information, just let me know.
ProjectID : 367723
I am working on a XIAO ESP32 S3 and trying to create an image detection. I exported the Arduino Library and imported it into my IDE. With help of the ESP32 Camera Example the Library offered I implemented the required code into my project. It works fine, the classifier runs, but when I want to print out the results, it only goes up to index 28 and then an error is thrown:
Q: 0.30078
R: 0.00000
S: 0.00000
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400556b4 PS : 0x00060a30 A0 : 0x8202f55c A1 : 0x3fceb5c0
A2 : 0x0000cbc5 A3 : 0x0000cbc1 A4 : 0x000000ff A5 : 0x0000ff00
A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x002e2e2e A9 : 0x00000020
A10 : 0x00060023 A11 : 0x00000001 A12 : 0x00000001 A13 : 0x00000004
A14 : 0x00060d23 A15 : 0x00000017 SAR : 0x00000020 EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000cbc5 LBEG : 0x400556d5 LEND : 0x400556e5 LCOUNT : 0xffffffff
Backtrace: 0x400556b1:0x3fceb5c0 |<-CORRUPTED
Here is the Code - the error is thrown when the for-loop index reaches 29.
ei::signal_t signal;
signal.total_length = 32 * 32;
// Run the classifier
EI_IMPULSE_ERROR eierr = run_classifier(&signal, &result, false);
Serial.print(eierr);
if (eierr != EI_IMPULSE_OK) {
Serial.printf("ERR: Failed to run classifier (%d)\n", eierr);
return;
// print the predictions
ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n", result.timing.dsp, result.timing.classification, result.timing.anomaly);
ei_printf(" %s: %.5f\n", result.classification[ix].label,
free(&result);
The library had predefined values which i increased to 36 to try if it solves the problem (I need all 26 Letters and 10 numbers → 36)
#define EI_CLASSIFIER_MAX_OBJECT_DETECTION_COUNT 36
#define EI_CLASSIFIER_MAX_LABELS_COUNT 36
I think I messed up something with reserving but I cannot solve it myself
If you need more Information just let me know.
Thanks for any help!
Tizi
March 21, 2024, 4:03pm
#2
When I run the Classifier with debug mode, I get this output, which reaches to the last char:
Features (0 ms.): 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.882353 0.000000 0.000000 0.000000 0.000000 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.000000 0.000000 0.000000 0.000000 0.000000 0.996078 0.996078 0.996078 0.996078 0.996078 0.882353 0.000000 0.000000 0.000000 0.000000 0.000000 0.996078 0.996078 0.996078 0.996078 0.996078 0.882353 0.000000 0.000000 0.000000 0.000000 0.113725 0.996078 0.996078 0.996078 0.996078 0.996078 0.882353 0.000000 0.996078 0.996078 0.000000 0.113725 0.996078 0.996078 0.996078 0.996078 0.996078 0.298039 0.113725 0.996078 0.996078 0.000000 0.698039 0.996078 0.996078 0.996078 0.996078 0.996078 0.000000 0.698039 0.996078 0.298039 0.000000 0.996078 0.996078 0.996078 0.996078 0.996078 0.882353 0.000000 0.698039 0.000000 0.000000 0.698039 0.996078 0.996078 0.996078 0.996078 0.996078 0.298039 0.000000 0.000000 0.000000 0.000000 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.000000 0.000000 0.000000 0.000000 0.113725 0.996078 0.996078 0.996078 0.996078 0.996078 0.882353 0.000000 0.000000 0.000000 0.000000 0.113725 0.996078 0.996078 0.996078 0.996078 0.996078 0.298039 0.000000 0.882353 0.000000 0.000000 0.113725 0.996078 0.996078 0.996078 0.996078 0.996078 0.000000 0.698039 0.996078 0.882353 0.000000 0.698039 0.996078 0.996078 0.996078 0.996078 0.882353 0.000000 0.996078 0.996078 0.882353 0.000000 0.996078 0.996078 0.996078 0.996078 0.996078 0.298039 0.113725 0.996078 0.996078 0.000000 0.113725 0.996078 0.996078 0.996078 0.996078 0.298039 0.000000 0.000000 0.000000 0.000000 0.000000 0.698039 0.996078 0.996078 0.996078 0.996078 0.000000 0.000000 0.000000 0.000000 0.000000 0.113725 0.996078 0.996078 0.996078 0.996078 0.882353 0.000000 0.000000 0.000000 0.000000 0.000000 0.996078 0.996078 0.996078 0.996078 0.996078 0.298039 0.000000 0.000000 0.000000 0.000000 0.698039 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.996078 0.611765 0.694118 0.003922 0.478431 0.223529 0.384314 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.796079 0.078431 0.000000 0.000000 0.000000 0.000000 0.027451 0.058824 0.164706 0.074510 0.054902 0.105882 0.000000 0.000000 0.000000 0.000000 0.749020 0.474510 0.211765 0.000000 0.254902 0.078431 0.058824 0.054902 0.152941 0.662745 0.443137 0.278431 0.164706 0.274510 0.164706 0.274510 0.164706 0.274510 0.164706 0.274510 0.164706 0.274510 0.137255 0.039216 0.109804 0.031373 0.180392 0.094118 0.003922 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
Predictions (time: 52 ms.):
0: 0.000000
1: 0.000000
2: 0.000000
3: 0.000000
4: 0.000000
5: 0.000000
6: 0.000000
7: 0.000000
8: 0.000000
9: 0.000000
A: 0.000000
B: 0.000000
C: 0.000000
D: 0.000000
E: 0.000000
F: 0.000000
G: 0.000000
H: 0.000000
I: 0.000000
J: 0.000000
K: 0.000000
L: 0.000000
M: 0.000000
N: 0.000000
O: 0.000000
P: 0.000000
Q: 0.996094
R: 0.000000
S: 0.000000
T: 0.000000
U: 0.000000
V: 0.000000
W: 0.000000
X: 0.000000
Y: 0.000000
Z: 0.000000
00
Predictions (DSP: 1065287680 ms., Classification: 1007671732 ms., Anomaly: 0 ms.):
0: 0.00000
1: 0.00000
2: 0.00000
3: 0.00000
4: 0.00000
5: 0.00000
6: 0.00000
7: 0.00000
8: 0.00000
9: 0.00000
A: 0.00000
B: 0.00000
C: 0.00000
D: 0.00000
E: 0.00000
F: 0.00000
G: 0.00000
H: 0.00000
I: 0.00000
J: 0.00000
K: 0.00000
L: 0.00000
M: 0.00000
N: 0.00000
O: 0.00000
P: 0.00000
Q: 0.99609
R: 0.00000
S: 0.00000
PC : 0x400556b4 PS : 0x00060a30 A0 : 0x8202f79c A1 : 0x3fceb5b0
A2 : 0x0001492d A3 : 0x00014929 A4 : 0x000000ff A5 : 0x0000ff00
A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x002e2e2e A9 : 0x3fceb5c0
A10 : 0x3fceb61c A11 : 0x00000004 A12 : 0x0000000f A13 : 0x00000080
A14 : 0x00000000 A15 : 0x0000000f SAR : 0x00000020 EXCCAUSE: 0x0000001c
EXCVADDR: 0x0001492d LBEG : 0x400556d5 LEND : 0x400556e5 LCOUNT : 0xffffffff
Backtrace: 0x400556b1:0x3fceb5b0 |<-CORRUPTED
Tizi
March 21, 2024, 6:13pm
#3
Hey, I figured it out while rubber-duck-debugging with my friend:
To override the EI_CLASSIFIER_MAX_LABELS_COUNT I had to define it before including the edgeimpulse lib.
It seems to have a default value of 25 and I’m wondering weather it is a bug, because I have 36 labels.
March 25, 2024, 10:31am
#4
Hi @Tizi
Not quite a bug. Its set by our embedded team to give more accurate estimations on ram consumption.
A soft limit on the value based on our test cases. @AIWintermuteAI had thoughts on this and may offer a comment if this will remain or be logged as an issue/feature request
