I think the Arduino example for the Data Forwarder may have a mistake in it. The Arduino LSM9DS1 provides accelerometer data in Gs. I believe that Edge Impulse is expecting the data to be in Meters/Second2 though. The conversion in the Arduino sample simply multiplies the sensor values by 10. It should instead be multiplying them by the constant for gravity: 9.80665. That is at least what is happening when you run inference. Not sure if it matters, but probably good to get right.
#include <Arduino_LSM9DS1.h>
void setup() {
Serial.begin(115200);
Serial.println("Started");
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1);
void loop() {
float x, y, z;
if (IMU.accelerationAvailable()) {
IMU.readAcceleration(x, y, z);
Serial.print(x * 10);
Serial.print('\t');
Serial.print(y * 10);
Serial.print('\t');
Serial.println(z * 10);
