Arduino Deployment Not Visible
Greetings! I’m a teacher learning along side my students as we explore what WIO Terminal and Edge Impulse can do. Kudos on the amazing platform!!!
One of my students created a accelerometer based model using her phone, but does not see the Arduino library option in the deployment tab. Any ideas where she may have gone wrong here? I have sample code once we have an Arduino library, but we don’t have the option to deploy in that format, only C++. Any ideas?
Hi @pway,
Thanks for your great feedback!
Could you share the project ID of your student?
Thanks,
@pway That’d indeed help, as we only ever hide the Arduino deploy option for non-FOMO object detection methods…
The link now does not download anything – it’s a link to an image – is the arduino library still available?
Hi @crippledko,
Can you provide your project ID so we can take a look at your deployment options to see if we can replicate the issue?
I am having the same issue when I trained an object detection model with two classes. There is no option to deploy to an Arduino Library, I am using Arduino Nicla Vision and I have attached a screenshot of the available options to deploy. Here is the project ID : 192284. Any help is appreciated :slight_smile:.
Hello @chinmaysahoo,
We hide the devices that won’t support your impulse.
You won’t be able to run a MobileNetv2 SSD model on the nicla vision, especially on 320x320 images.
You might want to try FOMO models: FOMO: Object detection for constrained devices - Edge Impulse Documentation
@louis thanks for the reply, if I use FOMO I am getting an option to upload it to Arduino but using FOMO is creating another issue. I am getting a zero F1 score after training. Could you please help me out, and tell me if I am doing anything wrong?
I can see that you only have 45 data samples in your project.
I’d start by collecting more data samples.
Feature Request
Instead of creating a morphing GUI wherein one must remember the GUI will look like this when I do that, simply overlay an icon or gray out the option with an asterisk * stating the selected device does not support this.
@MMarcial,
We’re currently reworking our Deployment page UI indeed.
@louis I trained using FOMO and I am getting a decent accuracy score but after I select the Arduino library in deployment and then build and download the library and try to import it to the Arduino IDE I get this error Error: 13 INTERNAL: Library install failed: archive is not valid: multiple files found in zip file top level, is it because of any IDE version incompatibility or some other issue? Please let me know.
You need to delete your old libraries.
If you installed Arduino with the standard method, you can see your Arduino Libraries in User/Documents/Arduino/Libraries. There you can delete the library your previously imported and import the new one from the IDE.
Can someone let me know how I can verify whether the memory requirements for my trained ml model is compatible with Arduino Nicla Vision?
Which memory?
The Ardy specs show:
  • Nicla RAM = 1MB
  • Your Model = 2.4M ← Not compatible
  • Nicla Flash = 2MB
  • Your Model = 0.0585MB ← Compatible
