Arduino BLE Sense libraries "invalid model for current sensor"
Every Arduino library example program includes the last 3 lines:
#error “Invalid model for current sensor”
#endif
I am wondering how this works because I cannot compile any of the examples, due to this error message.
Hi @pbalesparks,
If you cannot compile this means that the model you’ve exported does not match the sensor (in the example applcation).
See EI_CLASSIFIER_SENSOR in model-parameters/model_metadata.h. In your case it should read EI_CLASSIFIER_SENSOR_ACCELEROMETER.
Hello I have the solution
just follow the instructions
After including the library in the sketch
Then go to file and then copy the path of the library from preference
Go to the Library–> (Your edge impulse file ) → scr → Model-Perameters–>Model metadata…
Open the Model metadata file, and then find ( EI_CLASSIFIER_SENSOR )
in front of ( EI_CLASSIFIER_SENSOR ) you will find ( EI_CLASSIFIER_SENSOR_FUSION ) this
you need to change (EI_CLASSIFIER_SENSOR_FUSION) this to this ( EI_CLASSIFIER_SENSOR_ACCELEROMETER )
and then see this ( “accX + accY + accZ + gyrX + gyrY + gyrZ + magX + magY + magZ” )
change this to ( “accX + accY + accZ” )
and then
( #define EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME ) in front of this there is 9 do change 9 to 3 and then
SAVE now you can use it.
It will not show any error.
refresh it and use it.
