I am attempting to train a classification model with transfer learning.
I am getting the “Application exited with codee 137 (OOMKilled)” error, and am trying to understand why.
This model is classifying the dobble card deck.
I have 56 classes, and am using the MobileNetV2 with 160x160 input.
Here is a more verbose of the output:
Finished training
Saving best performing model...
Still saving model...
Converting TensorFlow Lite float32 model...
Attached to job 2441794...
Converting TensorFlow Lite int8 quantized model...
Calculating performance metrics...
Calculating inferencing time...
Calculating inferencing time OK
Profiling float32 model...
Profiling float32 model (tflite)...
/app/run-python-with-venv.sh: line 21: 10 Killed PATH=$PATH:/app/$VENV_NAME/.venv/bin /app/$VENV_NAME/.venv/bin/python3 -u $ARGS
Application exited with code 137 (OOMKilled)
Job failed (see above)
Project ID : 90777
Just an informative note, this model needs data augmentation, so it is over-fitting as it stands …
56 Classes & 560 images with augmentation on seems to be a big task for the current available compute instances. Could you at least try reducing the number of classes and try again?
This training takes only 10 minutes on a normal computer (without GPU) using Keras.
I am struggling to understand why this does not work in the cloud with EdgeImpulse.
This error occurs whether or not I have “data augmentation” enabled.
Reducing the number of classes (ie. cards) with render this model useless with the card game.
If this is truly a limitation of Edge Impulse, then I will find another use case to try.
Before I do that, what is the maximum number of classes supported by Edge Impulse ?
You can see in the log that I shared previously that the training and fine-tuning have completed.
The error seems to occur during the profiling step :
I have just increased compute resources for your project. Could you kindly try again to see whether it will bring the same error?
Regarding max no of classes, there isn’t really a theoretical value for that, but as you increase the number of classes it comes with some tradeoffs like: You will need more data to train your model of which you might run into issues like time or compute resources limits. Also more classes might make your model more complex and even bigger and it might not eventually fit on your target device.
Clinton,
Thank you, the training phase passed, and the (poor) results are as expected.
If I understand correctly, the profile step is the most demanding for compute resources ?
I wanted to attempt to achieve the same with EdgeImpulse.
As is, the model is overfitting, and needs more data, which I have implemented in a separate project (project ID : 89394)
This project, however, as you already predicted runs out of time.
Based on the reported jobs that have failed here on the forrum, feature generation & the profiling step are common, hence I would say they are the ones that consume much compute.
I have just increased your time limit for project 89394. Let me know if this helps.
@oduor_c ,
Thank you very much
This allowed the training and fine-tuning to work, achieving 99% accuracy ! but now crashes on the profiling part (like the previous project).
Mario.
Great Perfomance! To solve the crash at the profiling step, I have just increased compute resources for your project. You can now retrain your model and let me know if you face any other challenge.
Hi @AlbertaBeef - we’ve upped the memory limits for all jobs to be less stringent (they can go over memory limits without being killed immediately) and this should resolve all OOMKilled issues. We’re monitoring actively to see if any others happen and can tweak the limits if that’s the case.
