I have the raw sensor Arduino example running for different number of sensors from the DOCS here and my Github is here.
I see that the above example is fairly close to the motion standard example, meaning the continuous motion example should be fairly close to a continuous raw sensor example, just wondering if anyone has made a raw sensor continuous example that is easy to switch the number of raw sensors from say 3 to any number between 1 and 10?
I will try to work on a solution, but if anyone has already done it that would be nice.
Here is the continuous motion example:
* Copyright (c) 2021 EdgeImpulse Inc.
* SOFTWARE.
#include <ei-proximity-v04_inferencing.h>
#include <Arduino_LSM9DS1.h>
#define MAX_ACCEPTED_RANGE 2.0f // starting 03/2022, models are generated setting range to +-2, but this example use Arudino library which set range to +-4g. If you are using an older model, ignore this value and use 4.0f instead
** NOTE: If you run into TFLite arena allocation issue.
** This may be due to may dynamic memory fragmentation.
** Try defining "-DEI_CLASSIFIER_ALLOCATION_STATIC" in boards.local.txt (create
** if it doesn't exist) and copy this file to
** `<ARDUINO_CORE_INSTALL_PATH>/arduino/hardware/<mbed_core>/<core_version>/`.
** See
** (https://support.arduino.cc/hc/en-us/articles/360012076960-Where-are-the-installed-cores-located-)
** to find where Arduino installs cores on your machine.
** If the problem persists then there's not enough memory for this model and application.
static uint32_t run_inference_every_ms = 200;
static rtos::Thread inference_thread(osPriorityLow);
static float buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE] = { 0 };
static float inference_buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
/* Forward declaration */
void run_inference_background();
void setup()
Serial.begin(115200);
if (!IMU.begin()) {
ei_printf("Failed to initialize IMU!\r\n");
else {
ei_printf("IMU initialized\r\n");
return;
inference_thread.start(mbed::callback(&run_inference_background));
* @brief Return the sign of the number
* @param number
* @return int 1 if positive (or 0) -1 if negative
float ei_get_sign(float number) {
return (number >= 0.0) ? 1.0 : -1.0;
* @brief Run inferencing in the background.
// wait until we have a full buffer
delay((EI_CLASSIFIER_INTERVAL_MS * EI_CLASSIFIER_RAW_SAMPLE_COUNT) + 100);
// This is a structure that smoothens the output result
// With the default settings 70% of readings should be the same before classifying.
ei_classifier_smooth_t smooth;
ei_classifier_smooth_init(&smooth, 10 /* no. of readings */, 7 /* min. readings the same */, 0.8 /* min. confidence */, 0.3 /* max anomaly */);
while (1) {
// copy the buffer
memcpy(inference_buffer, buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE * sizeof(float));
signal_t signal;
int err = numpy::signal_from_buffer(inference_buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
if (err != 0) {
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
ei_printf("Predictions ");
ei_printf(": ");
// ei_classifier_smooth_update yields the predicted label
const char *prediction = ei_classifier_smooth_update(&smooth, &result);
ei_printf("%s ", prediction);
// print the cumulative results
ei_printf(" [ ");
for (size_t ix = 0; ix < smooth.count_size; ix++) {
ei_printf("%u", smooth.count[ix]);
if (ix != smooth.count_size + 1) {
ei_printf(", ");
else {
ei_printf(" ");
ei_printf("]\n");
delay(run_inference_every_ms);
ei_classifier_smooth_free(&smooth);
* @brief Get data and run inferencing
* @param[in] debug Get debug info if true
void loop()
while (1) {
// roll the buffer -3 points so we can overwrite the last one
numpy::roll(buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, -3);
// read to the end of the buffer
IMU.readAcceleration(
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3],
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2],
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1]
for (int i = 0; i < 3; i++) {
if (fabs(buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3 + i]) > MAX_ACCEPTED_RANGE) {
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3 + i] = ei_get_sign(buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3 + i]) * MAX_ACCEPTED_RANGE;
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3] *= CONVERT_G_TO_MS2;
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2] *= CONVERT_G_TO_MS2;
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1] *= CONVERT_G_TO_MS2;
// and wait for next tick
uint64_t time_to_wait = next_tick - micros();
delay((int)floor((float)time_to_wait / 1000.0f));
delayMicroseconds(time_to_wait % 1000);
#endif
and here is the DOCS arduino classify example linked to above
// Include the Arduino library here (something like your_project_inference.h)
// In the Arduino IDE see **File > Examples > Your project name - Edge Impulse > Static buffer** to get the exact name
#include <your_project_inference.h>
#define FREQUENCY_HZ EI_CLASSIFIER_FREQUENCY
#define INTERVAL_MS (1000 / (FREQUENCY_HZ + 1))
// to classify 1 frame of data you need EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE values
float features[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
// keep track of where we are in the feature array
size_t feature_ix = 0;
void setup() {
Serial.println("Started");
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1);
void loop() {
float x, y, z;
if (millis() > last_interval_ms + INTERVAL_MS) {
last_interval_ms = millis();
// read sensor data in exactly the same way as in the Data Forwarder example
IMU.readAcceleration(x, y, z);
// fill the features buffer
features[feature_ix++] = x * CONVERT_G_TO_MS2;
features[feature_ix++] = y * CONVERT_G_TO_MS2;
features[feature_ix++] = z * CONVERT_G_TO_MS2;
// features buffer full? then classify!
if (feature_ix == EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE) {
ei_impulse_result_t result;
// create signal from features frame
signal_t signal;
numpy::signal_from_buffer(features, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
// run classifier
EI_IMPULSE_ERROR res = run_classifier(&signal, &result, false);
if (res != 0) return;
// print predictions
ei_printf("%s:\t%.5f\n", result.classification[ix].label, result.classification[ix].value);
ei_printf("anomaly:\t%.3f\n", result.anomaly);
#endif
// reset features frame
feature_ix = 0;
va_list args;
va_start(args, format);
va_end(args);
if (r > 0) {
Serial.write(print_buf);
